Classic Hondas All Pre-1988 Hondas.
Expensive education about non-OEM parts
Old Dec 21, 2009 | 04:38 PM
52wrench's Avatar
New User
Default Expensive education about non-OEM parts
At least for fuel pumps and alternators. 87 Accord DX auto 139K miles. Original fuel pump lasted 20 years, 116K miles. Replaced with aftermarket Carter with new strainer and discharge filters and the tank was clean, no rust. That one lasted 22 months to 135K miles. Replaced again with a Carter that lasted TWO DAYS, obviously defective. Free replacement of course, again new strainer and filter. Car was driven to Fla from NY a couple weeks ago. Once down here the pump started acting up again, wouldn't run with every key on and it got really noisy. The pump relay was changed with the last pump change but just to make sure I jumpered right from the battery to the pump, same thing, sometimes it'd go, sometimes not. Pulled it out, bought a Honda replacement, can't even hear it run. Original alt lasted 106K miles, 19 years til 7/06. Installed aftermarket, lasted til 137K miles 11/09. Put in another aftermarket. Three days ago I go to start car in the morning, nothing, battery is totally dead. This was a new battery installed 8/09. Installed battery from other vehicle, made up a test light, disconnected neg cable from bat and connect test light between cable and neg post. Light is on bright with key off. Disconnect charge cable at alt, light goes out. Shorted diode in alt. Pull out alt and order Honda remanand get battery charged. Done with aftermarket except for filters, plugs, hoses. Live and learn.
Old Dec 21, 2009 | 04:42 PM
steveo135's Avatar
Default Re: Expensive education about non-OEM parts
This is why this forum preaches OEM parts
Old Dec 22, 2009 | 10:18 AM
1grex's Avatar
Too bad Honda discontinues the crap out of their stuff
Old Jan 4, 2010 | 06:52 PM
guysensei's Avatar
X2 ^^^ I would rather get a used oem part at the junkyard than a aftermarket part anyday
Old Jan 8, 2010 | 02:47 PM
mtncivic's Avatar
New User
Same with VW,everyone recommends Bosch...Domestic stuff doesn't work quite the same...
Old Jan 8, 2010 | 03:03 PM
E-AT_me's Avatar
i'm having issues with my alt. on my 91 too. replaced the OEM i think in june. now, 10k miles later (probably more) i'm getting power surges every now and then. it's like i have HID's!! not good.. will replace with a honda reman soon.
Old Jan 9, 2010 | 03:33 PM
NW Classic Honda's Avatar
Yes always use oem parts if you can.
Jody Lewis
Honda Ruckus and Scooters
Aug 7, 2018 10:13 PM
arielb1
Dec 4, 2009 12:19 PM
LS AzZkIkr
Feb 23, 2008 02:06 PM
garyc17
Sep 16, 2006 10:24 AM
