Suspension & Brakes Theory, alignment, spring rates....
what do u think about these spring rates...
Old Dec 21, 2009 | 02:04 PM
egjdmcivichatch's Avatar
Default what do u think about these spring rates...
450/500 gc's with koni yellows.
for a street/drag car mainly drag racing but with a little commute.
i dont mind the stiffness of the ride at all but i dont want the car to be dangerous to drive or hard to handle. just want a good setup for the track and still be able to drive the car home fine. car is a eg thats gonna be at stock ride height and using 22/8 slicks all motor.
any info would be appreciated.. also if u know a link that can answer my question shoot it to me cause i havent found a good answer yet so far.
thanx.
Old Dec 21, 2009 | 02:23 PM
TunerN00b's Avatar
Default Re: what do u think about these spring rates...
You'll be fine with those rates. Just don't put a monster rear ARB on it, or allow friends to drive it without some form of warning that the car will/could have lift throttle oversteer (probably, depending on tires, alignment, etc...).
Old Dec 21, 2009 | 02:25 PM
JW racing's Avatar
You should be fine.
Way back in the days when I used to DD/drag,I ran 350front 250rear on koni yellow,when I got to the track and bolted the slicks on,I would swap the rear springs real quick for some 1000s for launching.Then swap back the soft rear and drive home with a smooth ride while I enjoyed gandering at my timeslips.
Old Dec 21, 2009 | 02:49 PM
thanx for the info!
can u explain a little bit on lift throttle oversteer not familiar with this? tires are gonna be 195/50/15 falken zeix 912 for daily and no one is gonna be driven the car but me... also if a lower spring rate would make it more safe to drive that would be kool too.
let me know thanx for ur help.
Old Dec 21, 2009 | 04:04 PM
JW racing's Avatar
Originally Posted by egjdmcivichatch
thanx for the info!
The main concept is weight transfer,when you accel the car tilts back,when you brake the car tils forward.If you are too soft in front and/or too stiff in rear,when you lift the throttle with some steering input you get lots of weight transfer to the front,you will get loose or unstable and can/will spin.This is dangerous for someone who has little seat time or not enough experience driving a setup like that.
A differential also affects this oversteer,a stock diff will rotate more than a solid spool,as both wheels turn at equal rates on a spool.A stock diff allow both wheels to turn a different speeds allowing a "tighter circle" to be driven.
At the strip you should be fine to learn to get comfortable on this setup because you wont have any sudden steering inputs as you would/could on the civilian roads.
The trick I did swapping to stiff springs at the track was super safe and effective.
Old Dec 21, 2009 | 04:14 PM
TunerN00b's Avatar
Pretty much. With a stiffly rear sprung car, if you're cornering near the limit of traction (which you really shouldn't be doing on the street), then lifting off the throttle can allow the tail to slide out.
It isn't that problematic, unless you weren't expecting it (such as if you had to make an emergency maneuver while driving someone else's car).
The only issue with this is changes to the rear toe from the ride height change swapping spring rates will produce. Not a huge issue though.
Old Dec 21, 2009 | 05:31 PM
thanx alot for the info! really appreciate it.... im gonna go with that spring rate and hopefully nuthin happens... would it be safe lets say on the freeway?
Old Dec 21, 2009 | 05:46 PM
TunerN00b's Avatar
Sure.
Just know what the car will do under what conditions and don't drive like an idiot, and you'll be fine.
Old Dec 21, 2009 | 05:51 PM
alright kool no worries on that i rock the slow lane all day anyways!.
thanx again.
ribal_gh
Suspension & Brakes
21
Mar 3, 2013 10:18 AM
ruffrhyder
Suspension & Brakes
Sep 1, 2008 08:51 PM
7rrivera7
Sep 29, 2007 05:59 PM
kornerk12
Aug 24, 2006 03:01 PM
