questions about damage srp pistons, and marin bearing caps/bridge
Hi i have some questions, for you guys
is it possible to put the main bearing bridge og another block? or does it have to go with the one it was originally installed on?
another question, look at the picture i've attached, two of my pistons look this way.. a little tip os the edge have been bent inwards? problably cause of pre-ignition.. can i use this piston again? my engine broke a cylinder sleeve on cylinder 1. Piston 1 and 4 looks like this. Think it has been running with this damage for a long while..
regards
Kenan from , copenhagen denmark.
is it possible to put the main bearing bridge og another block? or does it have to go with the one it was originally installed on? another question, look at the picture i've attached, two of my pistons look this way.. a little tip os the edge have been bent inwards? problably cause of pre-ignition.. can i use this piston again? my engine broke a cylinder sleeve on cylinder 1. Piston 1 and 4 looks like this. Think it has been running with this damage for a long while..
regards
chad
15
Apr 21, 2010 09:16 AM
