E85, whats all the hype??
Old Dec 20, 2009 | 03:15 PM
Vagitarian's Avatar
Default E85, whats all the hype??
Gettin back into the Honda boosted scene, and reading alot of build threads and such, and I noticed alot of people mentionneding converting to E85
Is it just a type of gas available at the pump?? Im in canada, and ive personally never seen it at a pump.
Are there boost related benefits directly related to running e85?
Drawbacks??
Just looking for the quick and dirty
Old Dec 20, 2009 | 03:34 PM
spectacle's Avatar
Default Re: E85, whats all the hype??
Google is your friend.
Old Dec 20, 2009 | 03:40 PM
non-VTEC's Avatar
you wont find e85 in canada.
stick to sunoco 94.
Old Dec 20, 2009 | 03:52 PM
dpetro1's Avatar
http://www.raceone85.com/
Old Dec 20, 2009 | 03:54 PM
ColorCoated's Avatar
85 is the new alternative fuel. much cheaper than regular gasoline, and its also higher octane like race gas. You can get some great power numbers out of it. Draw backs it burns liek 60% more i think? i was talking to a tuner and he said you needed about 60% injector or something like that... i cant remember. but its along those lines.
So more power, cheaper fuel, draw backs? not many... except its hard to find. Its becoming available at pumps threw out the us, but my closest e85 station is about 45 minutes away.
Old Dec 21, 2009 | 05:55 AM
TheShodan's Avatar
Moderator
Something that a friend of a friend wrote regarding E85 by BG products. Interesting read for those considering E85 for POWER purposes outside of being "green".
http://www.pdfdownload.org/pdf2html/...09_ethanol.pdf
Old Dec 26, 2009 | 03:36 PM
Vagitarian's Avatar
Thanks for the read guys, but it aint available in canada so that goes out the window for me
Old Dec 27, 2009 | 10:44 AM
ScorpionT's Avatar
Actually, E85 has been around since the days of Henry Ford. It just faded away for awhile until people found it to be useful.
On an average E85 requires 20-25% more fuel for a stoich burn(complete burn with no waste). With the higher octane rating a benefit is (depending on boost level) you can run a higher CR, therefore making more power in relation to the amount of fuel used. Its just too bad E85 isnt common outside of the midwest.
Old Dec 27, 2009 | 12:10 PM
OregonGrown's Avatar
85 is the new alternative fuel. much cheaper than regular gasoline.
It is not ''much'' cheaper as its only about 20-25 cents less but you use 30 percent more. So it being cheaper definately isnt a reason people use it. Now ''much'' cheaper than race fuel but not regular pump gas.
Old Dec 27, 2009 | 01:56 PM
onefstek's Avatar
It may not be cheaper than the 92 octane, but e85 has a octane rating of about 105 and a burn rate that is 1/2 the burn rate of 92 octane. Therefore you can run more boost or more ignition timing and get more power.
Now compare the price of e85 with 110 octane race gas and you will find out that e85 is about 1/4 of the price of 110 octane.
Old Dec 27, 2009 | 02:14 PM
You apparently need to learn how to read. Was i comparing the prices of it to race fuel? i was replying to him saying ''it was a cheaper alternative to regular gasoline''.
I could have gone onto the specifics of why it is better than regular gasolin but simply was replying to him saying ''it was a cheaper alternative to regular gasoline''..
right now e85 is 2.29 in my area. If the 30 percent rule is correct you are now paying 2.99 in a sense. so its not cheaper than regular gasoline.
Old Dec 27, 2009 | 02:18 PM
sanman000719's Avatar
CHEAPER OR NOT THE GAINS FROM 2.65 A GALLON OVER 92 IS AWSOME, AND THE GAIN OER COST PER GALLON TO 110 ISNT EVEN CLOSE THESE ARE THE REASONS WE LOVE THE corn BABAY.
I MEAN IM ALL FOR SAVING SOME CASH
Old Dec 28, 2009 | 01:11 AM
HiProfile's Avatar
It's compared to race gas because that's why you'd run it - for more power with pump gas. The tuners I've talked to say ~8% increase over 93 octane is the norm, so you'll get much more if all you can get locally is 91. It also burns cooler & can be burned leaner, so you can help gas milage if you tune partial throttle correctly.
In some areas like the midwest, it can be very close to 93 in terms of price. Right now many states are using e70 due to the cold issue ethanol has, so make sure you know what you're pumping.
Old Dec 28, 2009 | 12:07 PM
E85B18's Avatar
What do you do if you tune your car in the winter on E85 which is actually E70. Then you fill up in the summer and the ethanol level has changed to a "true" E85?
Old Dec 28, 2009 | 04:12 PM
HiProfile's Avatar
Retune it, or turn your FPR up a tad and enjoy less HP than you could have.
Old Dec 28, 2009 | 04:52 PM
jdm602's Avatar
have 2 different maps on 2 different chips. or use a 2timer. or like hiprofile said, adjust your fpr. or if your a baller, buy a program and the demon then do whatever you want.
Old Dec 28, 2009 | 06:31 PM
xtegb16x's Avatar
i wish i had gas station that carried e85...
Old Dec 29, 2009 | 07:43 AM
E85B18's Avatar
Any idea about how much I should increase my fpr if I'm at about 475whp on 1000s? I'm running the s300, what's a 2timer or a "program and the demon"?
Old Dec 29, 2009 | 11:34 AM
jdm602's Avatar
2timer is a chip that has a ground on it and you can swtich maps by hooking the ground up. the demon is a board that goes in place of the chip kinda like hondatas boards but you can use a program like ectune, neptune or crome and tune on the fly and datalog via 1 usb cable.
well if you switch to e85 and your out of injector, then you need to bump up the base fuel pressure with the fpr.
Old Dec 29, 2009 | 12:38 PM
DC2BAR's Avatar
New User
My neighbors e85 tuned EK is a nightmare to start during the winter! the alcohol just doesn't do as well in cold weather i guess.
Old Dec 29, 2009 | 02:12 PM
E85B18's Avatar
Interesting. Ive never heard of a 2timer.
My car had the same issue in the winter so I switched back to 91.
Old Dec 29, 2009 | 02:16 PM
I agree in the winter time it is a pain in the rear, but i woudlnt change it for nothing the best thing besides affordable fuel for the power is the air temps at the track is awsome I can run 5-6 hot laps with out hitting 200 degrees
Old Dec 29, 2009 | 02:30 PM
jdm602's Avatar
you can get around cold starts on the tune if you know what your doing. if you garage it, you shouldnt have that big of a problem either.
Old Dec 29, 2009 | 04:19 PM
E85B18's Avatar
So you run E85 all year without touching your tune?
Old Dec 29, 2009 | 05:21 PM
jdm602's Avatar
ive ran mine all year round and havent had any problems. temps have varied from 15-115 f.
heres a little info on the 2timer.
http://www.moates.net/product_info.p...products_id=80
