I have Spoon TB should I get Ericks 70mm TB?
Old Sep 3, 2002 | 09:12 AM
rolow's Avatar
Default I have Spoon TB should I get Ericks 70mm TB?
I have a Spoon TB on my B20 vtec with ITR IM should I get an Ericks 70mm TB?
I know where I can still get a new one.
Do you consider this an upgrade?
Old Sep 3, 2002 | 09:55 AM
xtrafastcivic's Avatar
Default Re: I have Spoon TB should I get Ericks 70mm TB? (rolow)
erick tells most ppl they don't need the 70-68 tb they usually just need the 68-66 unless it's fully built
Old Sep 3, 2002 | 09:00 PM
rolow's Avatar
Default Re: I have Spoon TB should I get Ericks 70mm TB? (XtraFastCRX)
Up!
Old Sep 4, 2002 | 06:19 AM
J&D Motorsports's Avatar
I agree. Unless you have a significant amount of work done(12.5:1 compression,big cams,head work) the Spoon t.b. should do just fine. You would even be fine with a stock ITR t.b. "Bigger is better" is not the best motto to use when building an all motor Honda
cruzersi99
Feb 4, 2003 05:36 PM
user 9782082308
10
Jan 25, 2003 11:41 PM
OohOoh
Mar 12, 2002 07:51 AM
girlRacer
Sep 6, 2001 07:34 AM
