Valve cover seals leaking
Old Dec 20, 2009 | 04:52 AM
0c00l's Avatar
Default Valve cover seals leaking
Hi all, I rebuilt a d15b2 and converted from dpfi to mpfi and the first time I started it up it ran great with a little white smoke. after running it for an hour or so it now billows, especially when I floor the gas petal. I puled the spark plugs and noticed clean oil all over the tops where the plug wires connect to them and the bottoms were blackened. I'm guessing its the little round seals for the valve cover, I'm sure someone has encountered this and I was wandering what you have done to fix this?
I made sure everything was very clean and dry when I put the seals on the valve cover before placing it on the head.
Old Dec 20, 2009 | 04:57 AM
beansandrice's Avatar
Default Re: Valve cover seals leaking
I always use a little bit of grey silicon on those bad boys.
Old Dec 20, 2009 | 07:52 AM
scottmog's Avatar
or any time of high heat silicone. i use some free aerospace silicone i grab from around my shop lol
Old Dec 20, 2009 | 08:36 AM
0c00l's Avatar
Thanks alot, I will try that!
Old Dec 20, 2009 | 10:58 AM
BiG ChOr!Zo's Avatar
you can also buy a cheap replacement valve cover gasket set from egay...!!!
Old Dec 20, 2009 | 11:00 AM
JDMcreep's Avatar
yea they can be ur best friends when ur broke
garykf16
Apr 13, 2009 04:09 PM
standbackimapro
Apr 29, 2006 05:38 PM
krz6jdm
Apr 7, 2006 06:36 PM
blackflag188
Nov 9, 2004 04:54 PM
CalvitoSol
Jul 8, 2002 12:03 AM
