best way to route my 4 wires for my b16 swap
Old Sep 3, 2002 | 09:03 AM
takeheed's Avatar
Default best way to route my 4 wires for my b16 swap
that,and what gauge wire should i use
also havent looked yet but where can i get the connectors to install the wires?
Old Sep 3, 2002 | 10:17 AM
Mr Furball's Avatar
Default Re: best way to route my 4 wires for my b16 swap (adamjoey)
can you be a little more specific on the wires?
Old Sep 3, 2002 | 10:20 AM
ricodemus's Avatar
Default Re: best way to route my 4 wires for my b16 swap (FURBALL B-16)
he is speaking of the 4 wires for the b16 swap
2nd 02
vtec solenoid
oil pressure sensor
knock sensor
Old Sep 3, 2002 | 10:25 AM
SuperCivic's Avatar
it's really easy if you buy the hasport harness..75 bucks. if you don't want to spend the money it's easy to make one. i believe the knock sensor has to use shielded wire.
Old Sep 3, 2002 | 12:14 PM
takeheed's Avatar
Default Re: best way to route my 4 wires for my b16 swap (SuperCivic)
and the gauge should be the same size as all the other wires right ?
shouldnt I shield all 4 wires since they arnt loomed in with the harness?
Old Sep 3, 2002 | 12:30 PM
spettinger's Avatar
run all four through the main grommet just above the ECU. i routed all mine in a piece of wire loom. branch the knock sensor wire out of the loom above the thermostat, and let it follow over to the sensor. the rest proceed toward the front. i routed the ground for my vtec switch in the loom, grounded at the thermostat. as for the 2nd O2 wire, i located the 02 wire going into the ECU and split it. this is the best way i have found. you will need 1 small pin and 1 large pin to wire into the ECU plugs. if you don't have extra ECU connectors laying around, the pins can be purchased from honda cheaply. use small wire, approximately 16 guage, don't worry about shielding.
Acc3l3ratoR
May 1, 2019 07:41 PM
weekendboost
Audio / Security / Video
Mar 31, 2013 02:45 AM
highflyinhonda
Jun 3, 2007 05:26 PM
rudebwoy
Dec 30, 2003 01:46 PM
tbocrx
Aug 4, 2003 08:43 PM
