91 hatch STD to 95 b18b motor
Old Sep 3, 2002 | 08:44 AM
Audipwr1's Avatar
Default 91 hatch STD to 95 b18b motor
trying to work out wiring problems with this swap, can i modify the dash to accept an integra gauge cluster (the two are very different sizes and shapes), or is there some other perferred method? I really dont want to have to rewire the entire car, but would like to run OBD1 in the car.
Thanks
Old Sep 3, 2002 | 12:57 PM
Audipwr1's Avatar
Default Re: 91 hatch STD to 95 b18b motor (Audipwr1)
evening crowd, someone must know
Old Sep 5, 2002 | 07:14 PM
StorminMatt's Avatar
You don't need to completely rewire your car. Actually, the conversion is quite simple. You just need to change your ECU plugs to 1992-1995 plugs and change a few plugs under the hood. Take a look at my wiring guides for DX swaps on the hybrid board of resource.crx.org. Also, you don't need to change the gauge cluster. The in-dash VSS on 1988-1991 cars works fine with a 1992+ ECU.
Old Sep 6, 2002 | 07:53 AM
Audipwr1's Avatar
Default Re: 91 hatch STD to 95 b18b motor (StorminMatt)
dx have mpfi and std has single point though so all the in engine bay wiring has to change doesnt it?
widewhite
Sep 10, 2016 11:32 AM
ed6inms
Jul 2, 2013 07:30 PM
CO_CReX
22
Dec 15, 2006 04:41 PM
