Detailing Auto Detailing and Concours
Best way to clean an aluminum engine?
Old Dec 19, 2009 | 05:56 PM
Blazin Si's Avatar
Loved
Community Favorite
Default Best way to clean an aluminum engine?
I'm having a hell of a time cleaning up this engine. I've searched the forums and most people say to use Simple Green, engine cleaner, steel wool etc... I've tried all of that with minimal results. I even have a bit for my drill with a metal brush and that still takes a very long time, plus it's too big to fit in some of the spaces. I also have Mother's aluminum polish, tooth brushes and sandpaper. Nothing seems to do the trick.
Is there any way I can get the chemical that is used to hot tank an engine? I had my GSR block and head hot tanked when I built that motor and it came out spotless.
Old Dec 19, 2009 | 06:31 PM
vietjdmboi's Avatar
Default Re: Best way to clean an aluminum engine?
besides painting it.. the only other real way of getting it done is getting it media blasted. but since your motor is still together..i don't think you'll be going that route. its usually done when the engine is disassembled, the block will be put in a tumbler where media is blasted as it cleaning the surface.
here is a example of a block media blasted
Old Dec 19, 2009 | 06:36 PM
eghatch4sale's Avatar
Find a strong acid based aluminum wheel cleaner and presure wash it will work wonders ..... Simple green does not work
Old Dec 19, 2009 | 11:35 PM
RC_iBrian's Avatar
i was also wondering the same. idk if i wanna spray my motor but if i have to i will. more info would be great.
Old Dec 20, 2009 | 05:49 AM
RoadRage212's Avatar
USE A STEAM CLEANER. With a little degreaser and a wire brush for agitating, a steam cleaning has worked miracles for me. http://www.houston-imports.com/forum...roadragedetail
Old Dec 20, 2009 | 11:18 AM
dubzxallxstar's Avatar
carburetor cleaner...
Old Dec 21, 2009 | 05:33 PM
Blazin Si's Avatar
Loved
Community Favorite
Thanks guys, I really don't want to disassemble the engine for media blasting nor do I have access to a steam cleaner. Today I bought some sanding pads for my air tools, but it cut too deep and left scarring on the block.
It's really not that important if it's clean, I just thought I'd give it a try before I swap it in the car.
Old Dec 22, 2009 | 06:06 PM
Should have listend to the advice I gave you !!!!!!
Old Dec 22, 2009 | 06:12 PM
hondaman92's Avatar
like said above wheel cleaner is what i used with a tooth brush and after i got it real clean i cleared the whole block with high heat engine clear
Old Feb 4, 2010 | 10:18 AM
cockerkid008's Avatar
i used a wire toothbrush and a dremel with a small metal brush
Old Jun 26, 2011 | 12:13 AM
C_Rock77's Avatar
While this works like a champ....it will not only remove any dirt/grease/grime on the engine, but if you get it on the nuts/bolts, that nice gold galvanizing that is on it will go bye-bye, taking their corrosion resistance with it!
CivicEK321
May 1, 2008 06:09 AM
truevietluv636
17
May 17, 2007 03:03 PM
jlh22179tx
10
Mar 11, 2007 05:53 PM
Ash81
Mar 2, 2006 12:17 AM
EKen9
May 14, 2002 07:13 PM
