Electrical Issues: Do G3's have notorious ICU's like the G2's?
Old Dec 19, 2009 | 07:36 AM
PhoenixDownVII's Avatar
Default Electrical Issues: Do G3's have notorious ICU's like the G2's?
So I'll try and explain this as quickly yet as detailed as possible:
Replaced battery & alternator due to dead battery issues- worked for a while but then battery still died.
Battery checked okay.
Alternator checked okay.
Parasitic Drain Test: Failed! Car is drawing 1.4-1.8 Amps when car is off! Should be ~.4!
Pull fuses= Culprit is the "Interior Light" fuse. Once pulled, car is only drawing .3 amps when car is off. No more dead car in the morning!
So once this fuse was pulled:
No more interior lights (well duh)
No more rear defroster (Huh? That has it's own separate fuse!)
Car shows "Door Open" light with doors both closed! Once I open a door it gets brighter. When I move interior light to the "OFF" position (or "ON") as opposed to that middle-door-open setting- it goes off (and only lights up when the doors are truly open). Hmm, go figure.
So I just attempted to put that "interior light" 7.5a back in but move the interior light switch to OFF and see if the car settled down to .3amp draw- but it failed. Despite any setting on the interior light, simply having that fuse in place pushes the draw to 1.4amps once again. However my rear defrost worked now that the fuse was back in (no clue why)
The door jamb switches are fine, the switch to the interior light looks fine.
So I've read of bad resistors in the ICU unit (Behind the fuse panel) in the G2 integra's. Could a faulty ICU be causing all of this odd erratic behavior? Are the G3's also equipped with delicate ICU's? What else could it be?
Old Dec 19, 2009 | 06:32 PM
Default Re: Electrical Issues: Do G3's have notorious ICU's like the G2's?
FIXED IT!
The issue was my antenna motor.
My power antenna has had issues going up and down on its own lately so I forced it down with my hand.
Disconnecting the power antenna fixed it all. I put my Interior light fuse back in and now everything functions normal and I get only .2a draw on my battery when fully off! (Of course I just don't have a working antenna now but that's fine!)
Old Dec 19, 2009 | 06:54 PM
sde780's Avatar
wierd lol I need to disconnect mine too, it hums everytime I turn on/off the car even though it's broken
Old Dec 20, 2009 | 10:45 AM
Brice.Hayden's Avatar
No no no no notorious.
Old Aug 26, 2010 | 11:31 AM
tothewall's Avatar
Bringing this back for other people that might have had a hard time finding the solution as there is 100% accurate information here. I had the same problem in my car, actually bought a replacement icu, replaced it, same problem, disconnected the antennae motor after searching the board for an hour and everything is back to normal. Note: at least in my case I kept blowing the 7.5a interior light fuse, slot 21, as soon as I turned the car on. Keys in the ignition chime would work until I turned it over. What a ridiculous pain in the *** this was.
Bethiecaute
Honda Civic (2006 - 2015)
Jun 1, 2015 12:54 PM
Riptide_NVN
13
Aug 30, 2008 03:41 PM
teh hatton
Oct 10, 2007 07:49 AM
Mr.Speed
Dec 8, 2006 11:43 AM
oldscoutmaster
Aug 27, 2006 05:41 PM
