Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
15x8 ET0
Old Dec 19, 2009 | 06:34 AM
EJ1B18c's Avatar
Default 15x8 ET0
Hi lads i was thinking about buying a set of 8in wheels for my ej1. I want to fit 225/45/15
or 235/45/15. I now have 15x6.5 with 205/50/15 R888's with a 38mm offset.
If i go with a zero offset will the tyre and wheel clear the rear trail arm?
Modifying the front arches is ok but its the rear im worried about. Anyone running this set up please post up and let me know if its worth it. thanks
Old Dec 19, 2009 | 07:49 AM
powerneedy's Avatar
Default Re: 15x8 ET0
you can run a 15x8 et36 easy and still stay in the stock arches(maybe a little roll depending on camber and spring rates). a et0 is going to be out there quite a bit flares would be needed or expect to have the tires hanging out
Old Dec 19, 2009 | 09:54 AM
nsxtasy's Avatar
H-T Order of Merit
Originally Posted by EJ1B18c
I want to fit 225/45/15 or 235/45/15.
Do they sell 235/45-15 on your side of the pond? They don't here...
Old Dec 20, 2009 | 04:47 AM
ED9man's Avatar
ya, i'd be interested to hear about this in a street tire size
Old Dec 20, 2009 | 08:01 AM
Stinkycheezmonky's Avatar
Suspetise...
Yep, that's going to stick out a good 1 1/2" to 2" past the fender. Inside clearance will only improve as you go down numerically in offset (+45 to +38 for example).
Old Dec 21, 2009 | 04:20 AM
EJ1B18c's Avatar
Thanks ill try see if the wheel i want comes with a 36ET.
Mjalaly
Aug 11, 2015 04:47 AM
shahriar35
Dec 16, 2014 08:07 AM
White98LS
19
Aug 28, 2006 09:10 AM
moto27cm
20
Feb 1, 2006 06:12 AM
Andrew 825SM
Jun 14, 2005 07:00 PM
