CLEAN as FUDGE EG Hatch BEAST
IF YOU DONT LIKE THE CAR, THE PRICE, OR ANYTHING FROM THIS THREAD, KEEP UR FEELINGS AWAY FROM HERE.
PRICE IS 6300
I WILL TAKE DB8'S, EM1, OR EK HATCH'S FOR TRADES. PLEASE NOTHING ELSE
If yall interested holla at 561-3061518 or shared_pm me with any questions.
177K MILES ON CLUSTER
20K MILES ON ENGINE
CAR HAS A/C AND P/S
THIS CAR IS MAY DAILY AND IT RUNS HARD
Car was built by KAW (Kenzi Auto Works) in Kendall Florida. Everything was done perfect
Exterior: overall 9.5 out of 10
- Fresh Milano red paint 9 out of 10 (front lip has little chips and hood has a little chip where clear coat took a crap. someone spilled a little degreaser on it and let it dried)
- Body is 10 out of 10. it has no dents.
- Type R front lip
- Type R rear Lip
- Manual Spoon Mirrors
- Real carbon fiber duckbill spoiler
- Amber corner lights
- Black housing headlights
- 3000k HID headlights (yellow) (one ballast broke) i also have some 8000k bulbs
- Yellow fog lights
- 17" xtatic Black with chrome lip rims (No curb rash or scratches)
- 215-40-17 Nexxen 7000 brand new tires in the back
- 205-40-17 Nexxen 5000 brand new tires up front
Interior: overall 9.5 out of 10
- Carbon fiber Real Momo Steering wheel
- Gray Door panels in excelent condition
- Dark grey EG front seats. (driver side has a hole)
- Rear gray seats in perfect condition
- Rear grey cargo cover in perfect condition
- Ex cluster with 175000 miles
- Clock Block off plate
- Front dash wihtout Airbag
- Some silver pedals (just there cause i dont like the oem look)
- Dark gray carpet 8 out of 10
- Perfect condition plastics all the way around
- Cargo area plastics have scratch marks
- Type R shift booth
- Skunk 2 Shift ****
Suspension:
- Dropzone Coilovers
- Koni non adjustable shocks
- Gold Blox rear LCA's
- Hard Race Rear camber with pillow ball bushings (this aint just a regular camber kit with rubber)
- Hard race hard rubber bushings on fron LCA's
- Skunk 2 front camber kit
- Lower front bennen Strut bar
- Three point upper front bennen strut bar
- Upper rear Bronze Strut bar
- Extended front Wheel studs
Brakes:
- Si brakes all around
- Steel braided brake lines
- Cross not all the way thru drilled rotors. just for looks (drilled rotors only make braking worst by not letting disipate the temperature on a bigger surface)
- Fresh ceramic brake pads
ENGINE:
B20z2 bottom:
- Arp rod bolts
- LS crank
- Shootpeen LS rods
- Hone big end of rods
- Hone cilinder
- CTR Pistons
- Balance entire rotating assembly
- ACL bearings
- Golden Eagle Sandwich oil plate (includes niple to provide another oil line to head)
- Steel braided Oil hose for use with the golden eagle plate
- Golden eagle head gasket
- OEM piston Rings
- MOROSO Oil pan with respective gasket
93 GSR head (Uses the same bolt pattern as a B16 and ITR head):
- Port and polish
- Skunk 2 valve springs
- skunk 2 retainers
- skunk 2 cams
- Golden eagle adjustable cam gears
- OEM valve seals
- ITR Intake manifold
- ITR Trhotle body
- MOROSO cosmetic valve cover with respective gasket
- Greddy Oil Catch Can conected to head, block and oil pan
- AEM Fuel rail with gauge
- AEM fuel regulator
- RC 310cc Injectors
- walboro fuel pump
- NGK Sparks
- Oil pressure gaughe with steel braided lines
- Steel braided oil lines
- Hassport Engine mounts
- Engine torque damper
Breathing system LOL:
- K&N air filter
- K&N oil catch can breather
- K&N transmission breather
- Hytech replica headers
- High flow cat
- Replica N1 Mufler
- 2.5" Piping all aorund
Tranny
- B16 tranny with LSD
- Stage 2 clutch
- Fidanza flywheel
Cooling System:
- Samco Red radiator hoses
- C&R Full radiator
System:
- Pioner flip up indash dvd-radio 7" screen
- Infinti 6.5" speakers up front and back
- 10" kicker Sub in custom box
- Sony Explode Amp
- Optima Yellow top battery mounted in the trunk
- 4 gauges wires all aorund for power input and output
- B16 ECU with 2 chips. 1 chip for 93 octane at 203 whp and the other for race fuel at 229 whp
I will defenitely recomend tunning car again, i know this baby is capable of more power
I hope i did not forget anything but most likely i did
Thank you for your interest
PRICE IS 6300
20K MILES ON ENGINE
CAR HAS A/C AND P/S
- Type R front lip
- Type R rear Lip
- Yellow fog lights
Suspension:
Brakes:
ENGINE:
B20z2 bottom:
- Arp rod bolts
- LS crank
- Shootpeen LS rods
- Hone cilinder
- CTR Pistons
- ACL bearings
- OEM piston Rings
- Port and polish
- skunk 2 retainers
- skunk 2 cams
- OEM valve seals
- ITR Trhotle body
- walboro fuel pump
- NGK Sparks
- K&N air filter
- High flow cat
- Replica N1 Mufler
Tranny
- Stage 2 clutch
- Fidanza flywheel
Cooling System:
- C&R Full radiator
System:
- Sony Explode Amp
BinMop
17
Jul 6, 2007 03:22 PM
