94 Integra wants to die after driving fo 10 mins
I have a 94 ls integra car starts up good but after driving for about 10 minutes the cars seems like it wants to die and idles really bad. I unplug the map sensor and the cars runs a little bit better but misfire a little. I was wonder if the map sensor is bad or its a different problem. My car is a manual.
no check engine light and acts like its going to die and then i have to give it some gas or it will die after 2 minutes if i dont give it gas
I would check your main relay, fuel filter (if it hasnt been changed), and leaks in the intake system (ie van lines, gaskets, etc)...
Totally check your grounds, but that would affect your right off the batt.. not after a set amount of time..
How many miles, and what maintenance has been done it since you got it?
