code 7 and code 16, need help
Old Sep 3, 2002 | 07:29 AM
civicmark's Avatar
Default code 7 and code 16, need help
so i'm getting a code 7 (something's wrong with my throttel body or sensor) and a code 16 (something with my fuel injection) Any ideas? What should i check/replace?
thanks
edit: it's in an 88 REX dx
[Modified by civicmark, 4:30 PM 9/3/2002]
Old Sep 3, 2002 | 07:38 AM
USDM 4G VTEC's Avatar
Default Re: code 7 and code 16, need help (civicmark)
i always had the code 16 (fuel injector) on my STD.... even my friend did on his STD and cehck engine light never came on......... but from code 7 it smeans u gota bad TPS....... the resistance on the good TPS should be 3.2k-7.2k ohms.... check this resistacne between the yellow and green wire i beleive... i know yellow its one of them i can remember the other exact cabel color!
Old Sep 3, 2002 | 10:30 AM
civicmark's Avatar
Default Re: code 7 and code 16, need help (JDM EF9)
ok, i'm guessing this is the plug you're talking about?
(if the picture doesnt work, copy and paste this into your browser
http://www.geocities.com/klicker_sam/tps_sensor.txt.JPG
got_no_sol
Sep 12, 2010 07:46 AM
turboxsi
Jun 18, 2004 10:24 AM
Herminator
Jun 28, 2003 03:45 AM
