JDM D15B swap question
Hi Im planing to buy the D15b vetc and swap my non vtec motor out. My old engine died cause my a timing belt went bad. my bearings and rods were out so I plan to swap it. Anyways my question is, What parts will I need for the new vtec d15b?
This is where im purchasing my engine from. Does it look good?
http://lasvegas.craigslist.org/pts/1510727047.html
Here's my car. 91 hatch
I replace the head wit new gaskets and sneals. but i found out it wasn't that problem.
www.hmotorsonline.com
what he said above plus run the wiring for VTEC solenoid and VTEC pressure switch and if you are going to be using the P28 ECU you'll need to wire for 4 wire O2. Also you'll need to run the wires a bit longer for the fan switch from the back of your block to the new position on the thermostat housing. It'll bolt up to your transmission. Search around here for Z6/Y8 swap for the details.
Spooner15
15
Aug 1, 2013 04:14 AM
whitewonder
May 24, 2009 06:28 PM
