2000 Prelude F22 Swap....
Old Dec 18, 2009 | 09:18 AM
Simon Tibbett's Avatar
Default 2000 Prelude F22 Swap....
Does an F22 bolt directly into a 2000 Prelude?
Looking for the CHEAPEST engine available (car has no motor right now).
Old Dec 18, 2009 | 09:19 AM
kornkid21792's Avatar
Default Re: 2000 Prelude F22 Swap....
i do not believe that it does.
if your just looking for the motor they run about 800
Old Dec 18, 2009 | 09:28 AM
For an H22?
It may be a 97 not 2000 we're unsure. I've never messed with Preludes before.
Old Dec 18, 2009 | 10:18 AM
yassyspeed's Avatar
What's the sense of down grading your engine?
Old Dec 18, 2009 | 11:38 AM
gstrudler's Avatar
does this need to pass emissions? if not, you could drop in either an h22a (jdm), h22a1 (obd1) or h22a4 (obd2). if you do need to pass emissions, you can put in an h22a4, but be aware that '97 & '98 models had slightly different emissions setups and you will need the matching ecu to whichever motor you buy.
Old Dec 18, 2009 | 11:47 AM
No need for it to pass emissions, just looking for the cheapest motor I can throw in it. Not worried about downgrading.
Old Dec 18, 2009 | 11:59 AM
jlude90's Avatar
An F22 will work, it'll drop right in, you might just have to fiddle with wiring, but it has to be an OBDII F22.
Old Dec 18, 2009 | 02:05 PM
Does it matter which F22? Do they ALL bolt in? Tranny and motor? Wiring won't be an issue it will probably all be entirely stand alone.
Old Dec 19, 2009 | 09:08 AM
jlude90's Avatar
yeah, mounts are the exact same H to F
Old Dec 21, 2009 | 05:21 AM
PirateMcFred's Avatar
The mounts are not totally the same. To get an F22 into a Prelude you either need to toss a couple bolts out of the H22 mount (that attaches to the engine, the other half is not an issue) or use a 1990-1993 Accord engine mount, the one that bolts direclty to the F-series blocks. In other words: F22A engine mount, part number 11910-PT0-020:
Three out of four bolts is better than the alternative.
Grab the harness and the ECU and swap it all, otherwise you'll be cutting, lengthening and splicing wires to get connectors to sensors. The exhaust might not line up very well either. B-pipes are different. Good luck.
samstein
Aug 25, 2010 02:36 PM
JUDO_ED
Dec 15, 2009 01:53 PM
richjr
Mar 19, 2008 02:32 PM
silentvoice19
Mar 6, 2007 02:35 PM
tylerdurden99
Feb 27, 2003 08:25 PM
