ef9 si tranny problem HELP
Old Dec 18, 2009 | 09:00 AM
{EF9} GrEaZe m0nKeY's Avatar
Default ef9 si tranny problem HELP
i have an sohc si tranny,its stuck in 3 gear and i could move the shift stick but it still wouldd be in 3rd gear wont do nothing else,lets say i turn on the car on then i let go of the clutch the car will turn off almost like it was forced to turn off , my uncle said it was the pressure plate cause when i took it out it was soft as in i could flex the lil sticks way easyer then you suppost to0,so0 what ya think
Old Dec 18, 2009 | 09:05 AM
mayfly's Avatar
Default Re: ef9 si tranny problem HELP
u have a ef9? so how did u bolt ur si sohc d series tranny to ur b series? or are u lying and u really have a ed7? but to anwser ur question, can u shift the gears when the car is off? or is it permanently stuck, if so it isnt ur pressure plate its the pin that connects the ur linkage that is where u could be having your problems, also do u have tranny fluid in there?
Old Dec 18, 2009 | 09:08 AM
jlicrx's Avatar
if you can move the shifter to any position and the transmission remains in 3rd gear, most likely you have a broken 3-4 shift fork in the transmission
Old Dec 18, 2009 | 09:13 AM
mayfly u a lil b!@#$, and thanks jlicrx ,i was thinking the tranny messed up,i had a 3puck non spring clutch on there i know this clutch could brake the tranny easy when u power shifting ,but i could'nt fine any another clutch at all for this tranny
Old Dec 18, 2009 | 09:30 AM
mayfly's Avatar
im the b!@#$? ur the one power shifting and messing up ur transmission nd clutch, sowhile ur broke down nd not able to shift ill drive bye waving in my car that works lawl!
Old Dec 18, 2009 | 09:46 AM
yes your still the LIL B!@#$,im sorry i put my car to use at the track lol *****
99turboeg
Jun 5, 2005 01:42 PM
5 Skware
Apr 13, 2005 05:04 AM
RenoRacing
Feb 3, 2003 11:38 PM
