Msd Blaster SS Coil
Old Dec 17, 2009 | 06:35 PM
young_tuner's Avatar
Default Msd Blaster SS Coil
Ok well i just purchased http://www.summitracing.com/parts/MSD-8207/, and i was wondering if i have to have a msd ignition box to use this properly. The only reason i bought a new one is my stock one is cracked and this is much cheaper, and more effective. Also if you know where a write up is on installing this part that would be awesome. Also what about a Resistor, a msd tech told me no, but the paper included is telling me otherwise.
Thanks,
Ian
Last edited by young_tuner; Dec 17, 2009 at 07:25 PM. Reason: more information added
Old Dec 18, 2009 | 06:59 PM
spoolin-4's Avatar
Default Re: Msd Blaster SS Coil
I'm currently running the Blaster 2 external coil without the MSD 6 AL box. As for the wiring, I'd have to look at my car to tell you the wire match-ups and the car's sleeping right now, but I'm sure you could find it with a little bit of searching.
As for the resistor, I am not running one, and havn't been for 2 years now, without boost and with boost and no issues whatsoever.
Old Dec 19, 2009 | 08:19 AM
Thanks for the help spoolin, if you have a chance to look at your wiring and can update me it would be much appreciated. Thanks
Old Dec 20, 2009 | 03:21 PM
spoolin-4's Avatar
NP dude!
If I were to be online longer I'd try and find a link to help you out, but ya... lol
Hope all works for you!
Old Dec 20, 2009 | 08:24 PM
A little update spoolin, me and my friend hooked up the coil and my ignition control module fried i guess it was replaced, stock coil put back on and then the tach quit working. So i accomplished nothing but a broken tach.
Old Dec 21, 2009 | 07:03 PM
spoolin-4's Avatar
Hmm, weird. I remember putting 2 wires together and the other alone, as for the colours, like previously stating, cars away for the winter...
I did this mod right after the JDM H22a swap 2 years ago, so my memories a little faded to every step I did.
Sorry dude...
Old Dec 24, 2009 | 07:59 AM
My tach is now working there was a unplugged wire and i plugged it back up tach now works, but i still have stock ignition coil hooked up =/
Old Jan 13, 2010 | 04:10 PM
DillyD's Avatar
im also running a blaster external coil. Umm no resistor. I still have my stock honda coil plug in there i just connected the msd wires using flat male flat connectorsand plugged them into the stock harness for the coil. I did this so if the blaster coil quits it will be easy to just slap the old coil in and go. If you need a picture i could prolly get one let me know. Have been runnin this system for like 3 years no problem.
Old Jan 13, 2010 | 05:58 PM
spoolin-4's Avatar
Pretty good idea! Saves from re-soldering if something goes wrong.
Old Jan 14, 2010 | 08:24 AM
DillyD's Avatar
I thought so :D
ricekiller1
Jul 8, 2006 01:05 PM
GSR4U2NV
May 12, 2006 05:49 AM
bloodgulch
May 4, 2006 03:23 AM
DuMpTuBe
Mar 23, 2003 12:49 AM
