98 Integra Built all motor!
Hello, Im just seeing whats out there, I'd prefer to trade but will sell. Please Give me a trade offer that makes sense. I may consider trucks as well.
(386)-986-8570, Trevor
****This car Makes for a perfect daily driver, in normal traffic it runs as if a stock gsr, other than a little lopey idle. Car does not bog, or drive like crap. very smooth****
**The car was Just tuned recently, all the details can be found in this link about the tune:
LINK
Got My integra tuned.. - OrlandoForums.com :: #1 Online Community for Central Florida
Its a 1998 Integra LS CLEAN TITLE With a B18c (jdm gsr) In it, The body has about 140k on it. 4k on motor. All power options work, Interior is really Clean, Gsr blades with 80% Falkon Tires. All the car really needs it some paint work on the front end, other that that the car is really clean. Car has NO problems. I have papers for most of the major parts. CAR HAS POWER STEERING AND COLD A/C! The only thing i dont really care for about the car is that it has an LS tranny, but its mint with no grindes..but the car stills pulls great with this tranny (nice for highway crusing)
$4500, And bring your own wheels.
Head-
-Supertech valve springs and retainers (new)
-Omni Power valves
-Ferrea valve seals
-port and polish
-Skunk2 Pro 1 cams (new)
-Skunk2 Pro series cam gears (new)
-Skunk2 Pro series intake manifold (new)
-KiddRacing RMF knockoff header (new)
-OEM headgasket w/slight spacer (new)
Bottom end-
-Fresh hone from machine shop
-ARP head studs (new)
-ACL bearings (rod/Main) (new)
-Stock gsr rods
-Civic type-R pistons (new)
-OEM Honda piston rings (new)
-MFactory magnetic drain plug (new)
Suspension-
-Ground Control coilovers (new) Rides Great!!
-Koni yellow struts (new)
-Omni power upper control arms (new)
-Recent alignment
Other mods-
-Exedy clutch disk (new)
-AEM short ram intake (new)
-B&M fuel pressure gauge (new)
-B&M fuel pressure regulator
-New OEM water pump
-New timing belt
-All gaskets and seals were replaced with OEM pieces
-Autometer oil pressure gauge (installed but not hooked up currently)
-AEM Wideband air/fuel gauge (new)
-Energy suspension shifter bushings (new)
-RC 310cc fuel injectors
-Walbro 255 fuel pump
-Omni power test pipe
-Greddy Evo2 Exhaust Sounds Great
-Boomslang OBD2-OBD1 conversion harness
-P28 ECU Tuned on EcTune Details in link above ^
Audio-
-Eclipse headunit
-Polk speakers front and rear Clean Crisp Sound
-Aftermarket tweeters (not sure of the brand)
Random stuff-
Itr shift boot
Skunk2 ****
6K Hids
Gorilla lug nuts
Slim Fans
Torque mount inserts
Could Use a Oil Catch can
Sorry for the Low quality pics, If you are INTERESTED i can take better pics and email or post up here.
Please bump if you view, thanks
CONTACT INFO: 386-986-8570, Trevor
LINK
Head-
-Omni Power valves
-Ferrea valve seals
-port and polish
Bottom end-
-Stock gsr rods
Suspension-
-Recent alignment
Other mods-
-New OEM water pump
-New timing belt
Audio-
-Eclipse headunit
Random stuff-
Itr shift boot
Skunk2 ****
6K Hids
Gorilla lug nuts
Slim Fans
izzyaccord
Jan 1, 2010 04:56 AM
izzyaccord
Dec 30, 2009 01:32 PM
