No clutch peddle at all
Old Dec 17, 2009 | 04:52 PM
Superaison's Avatar
Default No clutch peddle at all
Ok. I swapped the engine in my prelude (same engine to same engine) I just had a bad one.
Well, I replaced axles and such. Thing is, I have NO clutch peddle. It comes back and all, but pressing it in takes no effort. We tried bleeding it and there is next to no pressure. I have a feeling there is air in the master cylinder. I don't know what the problem is honestly. Could anyone give me some feedback? I have a 94 Prelude S
Old Dec 17, 2009 | 05:19 PM
5SpdH22's Avatar
something gnarly
Active Streak: 30 Days
Default Re: No clutch peddle at all
No clutch pedal is a common problem found in cars with an automatic transmission.
It's probably either the slave or master cylinder.
Old Dec 17, 2009 | 05:37 PM
Superaison's Avatar
Well, the master and slave cylinder worked perfectly before the swap on sunday... that's what I don't get.
Old Dec 17, 2009 | 05:43 PM
Doc13's Avatar
Lmao.
Old Dec 17, 2009 | 06:03 PM
313hitman's Avatar
you sure you put the clutch and pressure plate back on aligned perfectly? I vacuum bled my slave when I had the same problem after replacing it
Old Dec 17, 2009 | 06:29 PM
Superaison's Avatar
Yes. I have NO pressure in the line. Maybe I just have too much air in there.
Old Dec 18, 2009 | 11:11 AM
dpetro1's Avatar
i just LOLed so hard at work, now my co-workers are looking at me funny
FO SHO
Transmission & Drivetrain
May 25, 2011 09:22 AM
jdmeg9
Feb 22, 2009 02:44 PM
T"u"Rtle
Apr 21, 2006 10:17 AM
matto2413
Sep 11, 2005 09:01 PM
anewfoundkevin
Sep 2, 2004 04:56 PM
