WTB: gsr b18c1 shortblock
haha 00 isn't a obd1 block its obd2
and if you want a bare block it doesnt matter the obd you make it which you want,
i have a 96 gsr bare block lmk what all you need
True the bare blocks are the same, but there are other parts that can add up quickly, if you buy an OBD2 block and have to switch over to OBD1 parts, such as: oil pump, lower timing belt cover, timing belt gear, oil cooler, cooler hoses, and coolant tube. That can easily add up to a couple hundred bucks of unecessary expenses.
i have one in cali that ill sell you for cheap. $200 plus shipping. it has a crack in one sleeve but i will give you some brand new in box darton sleeves. let me know.
I HAVE A FULLY BUILT GSR SHORT BLOCK WITH DARTEN SLEEVES I ALSO HAVE THE HEAD WITH IT TO ITS AN AMAZING MOTOR THAT I COULD NOT AFFORD TO FINISH IF YOU WOULD LIKE TO CHECK OUT SOME OF THE OTHER MOTORS MADE BY THE PLACE THAT MADE MINE CHECK OUT DH-RACING.COM I HAD MINE SPECIALLY BUILT IF YOU GET THE COMPLETTE SETTUP OF WHAT I GOT I KNOW IT HAS 14-1 COMP BUILT TO RUN 11 SEC ALL MOTOR. AND NOTHING HAS EVER BEEN TOUCHED BY OIL AND IF YOU WANT TO GIVE ME A CALL MY NUMBER IS 641-691-3033 NAME IS CHAD
TheCrimsonGhost666
Mid-Atlantic (Sales)
Oct 1, 2009 07:49 AM
