► TW: Custom GT30 S2000 turbo kit ◄
* T/W Custom GT3076 turbo kit *
-Garrett GT3076 turbo with Tial stainless V-Band ex. housing
-Tial 44mm wastegate w/ 4psi and 10psi springs
-Custom stainless top mount manifold
-Custom 3" downpipe w/recirculated wastegate dump
-Precision/Inline Pro "600hp" intercooler w/custom brackets
-4ply silicone couplers and T-bolt clamps
-Custom mild steel intercooler piping
-HKS SSQV blow off valve
-Oil feed/drain lines and fittings with feed restrictor
-Coolant lines and fittings
-4" aluminum inlet pipe w/ K&N filter
I would supply my oil pan with the fitting welded in, my oil cooler with heat shield and fitting welded on, and water fitting above oil cooler with fitting welded on. However I would need the buyers stock parts in exchange. This would make this kit go on a stock car VERY quickly and easily!
$2800 plus shipping
Build thread here... https://honda-tech.com/forums/honda-s2000-5/gt30-s2000-build-2508429/
If the kit sells, and ONLY if the kit sells, I will also be selling the following...
-Omni 4bar map
-AEM EMS 1052 w/Modifry temp gauge fix (tuned for this setup)
-Mac/AEM boost solenoid
-Injector Dynamics 1000cc injectors
-Walbro 255 pump
-Dekka/Braille battery relocation bracket
-Fuse box relocation bracket
-AEM wideband gauge
-VDO boost gauge
-Autometer gauge pod
Live*JDM
Dec 10, 2007 09:10 AM
ebpcivicsi1234
Mar 9, 2005 01:49 AM
