CRX b16a obd0 runs like crap untill check engine light comes on
Old Dec 17, 2009 | 12:24 PM
lakahang's Avatar
Default CRX b16a obd0 runs like crap untill check engine light comes on
just like the title says, it'll run like crap untill it warms up, it'll run alittle better, and then it'll finally feel decently quick when the check engine light comes on, about 20 mins into driving it......
vtec doesn't work either
the only code(s) its throwing is:
-code 6(coolant temp sensor) at times
-code 12(dont even know what this is)
the ecu is a pr3 btw
the only thing i can think thats wrong with it is the ecu is bad, i re-did the wiring and everything......
Old Dec 17, 2009 | 12:37 PM
.Manny.'s Avatar
Touching My Member
Default Re: CRX b16a obd0 runs like crap untill check engine light comes on
fix the codes. if not, try another ECU
Old Dec 17, 2009 | 02:10 PM
lakahang's Avatar
i fixed the coolant temp sensor, but it still comes on, what about the code 12 that doesnt even exist atleast to my knowlege weird huh
Old Dec 17, 2009 | 02:28 PM
iheartteal's Avatar
yea i would guess that you need a new ecu if it thinks you have and egr valve
Old Dec 19, 2009 | 09:21 AM
lakahang's Avatar
any more suggestions
Old Dec 19, 2009 | 09:31 AM
ef yu's Avatar
my guess is that you have an automatic ecu. maybe thats why its throwing a EGR code.
try another ecu.
(i had a PR4 ecu when running my B16a and it ran okay. not great, yet not terrible) try another ecu.
Old Dec 19, 2009 | 01:40 PM
hiproof's Avatar
Test with open header to make sure the exhaust is not to small as that happened to me, it was a slow rotting inside the cat. Had us all stumped for a long time.
Old Dec 19, 2009 | 01:45 PM
SIred91's Avatar
Rainman
are you sure your 02 sensors are hooked up properly?
Old Dec 19, 2009 | 03:22 PM
lakahang's Avatar
i checked already they all lead to an area, and its not an o2 sensor code anyways
Old Dec 19, 2009 | 03:23 PM
lakahang's Avatar
i have a greddy catback, im pretty sure that it wouldnt be that, thanks though
sloweh3
Jan 1, 2005 12:18 PM
Nevaeh
Dec 20, 2004 09:36 PM
jsteezy1290
Mar 28, 2004 06:17 PM
stockintegra
Mar 27, 2004 02:13 PM
