Chicago:1991 Mitsubishi 3000gt VR4
Hey guys, I have a very good condition and rare 3000gt vr4 for sale. This car is absolutely unmolested and nothing done to it, not even a blow off valve. Here is a quick background on the car, the chasis has roughly 115k but the engine was recently purchased with roughly 40-50k. We bought a JDM longblock since the old motor blew. Car still uses the original transmission and harness. Car runs, drives, idles perfectly only flaws it has is the small grind going into 3rd gear at high RPM. No CEL light is showing but the Touring and Anti Brake is active. I never had a chance to get around to see what is wrong but it could be as simple as a dirty sensor. Both of those lights does NOT effect the car whatsoever, even the wing still moves up and down on speeds over 45MPH. This is a very well kept car and definitely shows. Brakes are very very good with the 4 piston calipers and wide 17" tires. AC is ice blow and Heat is very hot. This would be a perfect winter or summer car with the all wheel drive. If you have any questions please contact me, as well I have plenty more pictures. Price is 7,500 obo and trades are welcome, pending on item. If trading for another car, rather have an import and no junk cars please. Thank you
Thanks for the bump, I agree on the work on this motor. It's a pain but I assure you, this car does not need any done to it. Turbo's spool very well and no play whatsoever. Believe me, it's a blast to drive.
aaaahh...yes you did....you had the 240 right???.... and about info on the car it needs a little bit of work right now, 156k on the body (still no rust, clean underbody)....was swapped at 145k with a j-spec swap...brand new clutch (one-off 400+whp capacity) (-1000 on it) 3" hsk super power exhaust (single 4 3/4" muffler), upgraded intercooler, and other than that it is bone stock.
