any OEM rear brake upgrades?
I am doing a da rear disc conversion onto my EF and I was wondering if there are any big brake upgrades that can be pieced together using oem parts.
for example: my front brakes are 11" vw rotors with S2000 calipers. Direct bolt on..
anything like this for the integra rear?
I know fastbrakes sells a kit, but that is with a bracket and using the stock caliper.. (which I think is quite pointless because it is the same brake pad surface area so where is the benefit? a little more disk area = better cooling?)
anyways.. any info is appreciated.
Thanks guys
Thanks guys
There is some indication that 02-03 EP3 (Civic Si) rear brakes can work. I recall a more specific thread, but cannto find it now. (You can look.)
https://honda-tech.com/forums/acura-integra-6/ep3-rear-brake-fit-dc2-874077/
I am a little confused by this, as S2000 calipers use a 300mm (11.81") rotor.
https://honda-tech.com/forums/showthread.php?t=874077
as for the S2000 brakes here is a link. https://honda-tech.com/forums/showth...2211517&page=2 the swap is pictured about half way down.
cheers!
and here is the page you were referring to!
thanks again!
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/its-done-10-3%22-ep3-rear-disc-conversion-ek-mc-ek-info-1090780/
thanks again!
BrakeExpert
Suspension & Brakes
23
Feb 20, 2014 04:55 PM
Mr. Choi
Nov 13, 2004 03:30 PM
