anyone have pics of the back of their motor?
...as the topic says. I'm looking for pics of the back of any b-series motor. I need reference for routing the wiring harness.
Thanks
Thanks
http://www.geocities.com/b20bvtecpre...lock.12.08.jpg
cut and paste the link to work - sorry
back of a dirty B16A,
basically plug the alternator wires in, then hte oil pressure sensor and knock sensor, then teh intake manifold its and make sure you use hte crades as they sit on hte manifold support piece...
hth,
t..
[Modified by tinkerbell, 3:56 PM 9/4/2002]
[Modified by tinkerbell, 3:58 PM 9/4/2002]
hth,
t..
Here are a few pics from my GS-R swap. The last one will probably look drastically different from yours though, as I have removed the stock black box, rerouted coolant hoses, installed a freeze plug and tapped previously blocked off points. Either way, HTH.
thanks guys. That's all I needed. I couldn't remember if the harness was routed above or below the intake mani. support bracket on the ITR motors.
fullblown
Feb 13, 2005 08:37 PM
Asimonk
Acura TL, RL & ZDX
Jun 27, 2003 11:11 PM
