turbo header questions!
Old Dec 16, 2009 | 06:54 PM
frizzle's Avatar
Default turbo header questions!
ive got a b16 and all i want to know is if the eclipse 4g63 exhaust manifold mount to a d series or a b series block. im think of tradin some rims for a 16g kit for my ef and he said the kits been on his eclipse and his buddys civic. and help to clear this up will be appreciated guys thanks.
Old Dec 17, 2009 | 05:41 AM
killercrx91's Avatar
Default Re: turbo header questions!
I don't think the headers can fit. You can try but it may be hard.
Old Dec 17, 2009 | 05:58 AM
placid888's Avatar
no way it's going to be plug and play, unless custom drill to bolt on, if that the case i doubt exhaust holes would match up, one cylinder have better flow that other
Old Dec 20, 2009 | 06:54 PM
sktdvs14's Avatar
like they said....ive never seen or heard of it being plug and play. you may have to retap the header bolt plate or port match the header. good luck tho..tell us how it turns out.
my .02 if you trade the kit great..just keep most of the kit and buy some b series turbo manifold down the line to complete the kit.
Old Dec 20, 2009 | 07:22 PM
88Hatchy's Avatar
If the price is right on the kit then I would get it. There are adapter plates made that adapt Mitsubishi turbochargers to the factory HF exhaust manifolds. I forget who makes them, but if you ask around in the Welding and Fabrication forum you could get an answer.
Old Dec 20, 2009 | 08:12 PM
frizzle's Avatar
Here my next question... If I'm just looking at the manifolds how much of a diff is there so I can tell between b series and d series could I measure the port row length and compare to the header on my b16?
Old Dec 20, 2009 | 08:21 PM
frizzle's Avatar
I think I will just get it especially if the turbo is good. I mean its on trade for some rims I didn't pay squat for. I guess I could just find the b series manifold with dsm flange? It has an internal wastegate also. I'm new wit turbo guys. Is this good? Is there anyhing special I need to know because of that? Thanks again for the replys
Old Dec 20, 2009 | 09:00 PM
88Hatchy's Avatar
You will need a good EMS, hondata, crome, ectune, neptune, etc. If you have not already converted to OBD1 then now would be good time, before installing the turbo system. Bigger injectors are also a must, I wouldn't consider anything smaller than a 750cc, just to be safe. You could learn a lot just by reading the Forced Induction forum for a while. You will get a good idea of what you need and what you don't, how much power can be made safely, etc. Before you ask any questions there make sure you already have a general plan and a budget set, so you don't get flamed. Good luck.
Old Dec 20, 2009 | 10:27 PM
frizzle's Avatar
Yeah I'm obd1 already si2 in fact and I wasn't planin on huge boost just street 8 to 10 on a daily you know? I've got a p28 with the mugen style chip specs. It runs clean. Can you dnld differnt base maps to that chip?I'd prolly need like that Neptune usb installed huh? I've got some 310cc that I thought about using. The only shops around here tune s300 and I will find a way around that. Or at least I hope lol .thanks guys tax returns comin up so I'm just figuring stuff out and this ride will be boostin by the way you can check it out in the garage 91 hatch "siR2"
DCRB
Sep 6, 2010 08:10 AM
Jpad626
Oct 6, 2009 05:19 AM
notburton06
Feb 2, 2007 03:16 PM
idriveadelsol7
Dec 19, 2005 11:39 AM
