TW/FS: Rare Discontinued Black APEXi S-AFC II
TESTING WATERS: parting out due to recent totaling of my ek hatch. up for sale a rare discontinued black colored apexi super air flow converter ii in excellent condition. bought when first came out for $250.00+ dont remember exactly but still have the receipt somewhere around the house.
WILL ONLY COME WITH, controller and the wire harness connected to the controller. YOU GET EXACTLY WHAT YOU SEE IN THE PICTURES BELOW. as for the other half of the pig-tail wire harness i was using boomslang custom wire ecu harness and was sold separately few days ago on local cg.
mainly taking offers right now will sell at the right price if not will keep for my next car. i know how much this is worth so please dont lowball. thanks for the time!
you can get the custom boomslang wire harness for your car here.
http://www.redlinemotive.com/part-nu...on/bf08004.asp
SPEC INFO:
The SUPER AFC II is a fuel adjustment controller in which the airflow sensor signal or the pressure sensor signal can be modified in a 12 point RPM range by 1% increments to increase/decrease fuel in a range of +50% to ?50%. The RPM to be corrected can be optionally set in 200 RPM increments, and corrections can be made according to throttle opening amounts. In a turbo equipped vehicle with a hot wire type airflow meter, this controller provides a preventive function for engine stall due to blow-back during throttle return. The controller, which includes a knocking meter, allows the monitoring of knock levels check keeping the engine under its optimum condition at all times. (Vehicle must have a factory knock sensor).
SPEC INFO:
wickedEM1
Apr 11, 2005 07:49 PM
