Another brake question
OK so I have a 90 hatch std.
I have the complete trailing arm assembly from a 90 integra ls.
The bushings are already in and all that good stuff. I ordered e-brake cables from a 91 si. When I got them to put them on they didnt match with the right connector at the caliper. The ones I got were a ball on the end. Almost similar to where the lines connects inside the car. The ones on the trailing arm are in the shape of a U with a pin and cotter pin going through them
I would have used the integra ones but everybody says they will be too long. So heres my Question: Which E-brake cables do I need?
All help will be greatly appreciated. Thanks
if you have a ef hatch & trying to do rear disk brake conversions you can use any of these following e-brake cables:
90-93 da coupe or sedan
94-01 dc coupe or sedan
92-95 civic ex sedan
* you cannot use 99-00 civic si because they are a little bit shorter.
I see Charlie listed the 92-95 ex sedan as an option, anyone know if the del sol si is the same part?
EDIT: nevermind, just checked and the Del Sol SI ebrake cables and the 92-95 EX cables are the same.
the teg cables may be bit longer but not sooper long to where you cant just tuck some of the slack. i swapped rear discs onto my 90 dx. used the entire trailing arms from a 99 gsr. no problems
90civicstdgold
Jan 13, 2010 10:18 AM
quintanaporvida
Aug 13, 2005 05:06 PM
