Help! Upper Trans Mount Doesn't Line Up!
Old Dec 15, 2009 | 06:58 PM
phileng04's Avatar
Default Help! Upper Trans Mount Doesn't Line Up!
Have a 95 civic auto which I am in the process of converting to manual. Has a B16 motor already swapped and had an auto tranny. Just put the ls tranny in and the conversion top tranny mount I bought from innovative is off by about 1/4-1/2" to the inside. I can barely see the hole in the bushing. Currently the only other mount attached is the driver side engine mount. I am wondering if:
A) I should not have unbolted the rear mount from the engine though I don't see how I would have gotten the trans out
B) The motor can be pushed over further with a pry bar and where a good spot to pry from would be?
Thanks so much.
Old Dec 15, 2009 | 08:29 PM
phileng04's Avatar
Default Re: Help! Upper Trans Mount Doesn't Line Up!
Never mind. Prying worked. Now just have to get the rear mount lined up.
TwentyTwo91
May 7, 2011 04:10 AM
KPowerSquadron
Aug 16, 2010 04:49 PM
KickStart2323
Mar 8, 2007 06:23 AM
eg8ferio
Apr 26, 2006 12:44 PM
DC2-JRSC'd
Aug 4, 2004 09:55 AM
