hood wont open (searched)
Old Dec 15, 2009 | 03:05 PM
KINGVEM^^ED6's Avatar
Default hood wont open (searched)
So I got a 91 dx hatch when I got it the hood cable was snapped so I got a new cable put it in all was fine. but I went to open it today and then it wouldnt close.....so I adjusted it but now it won't open I need like a mad discription thanks.............
Old Dec 15, 2009 | 03:13 PM
Default Re: hood wont open (searched)
ttt
Old Dec 15, 2009 | 03:24 PM
BiG ChOr!Zo's Avatar
pull the hood cable out towards the driverside wheel and have someone pull up the hood...!!!
crx_si-r's Avatar
Here is what you need to do.
Take a long (18" preferably) screw driver, position it between your bumper and a/c condenser. Then position it where your hood latch is at, the big bolt with a spring you adjusted earlier and with a hammer hit it. Then it should pop open the first click. Then open it like normal.
Old Dec 15, 2009 | 07:03 PM
Thanks for all the help and dayum 18 inch ill see what happens thanks again
Old Dec 15, 2009 | 07:14 PM
crx_si-r's Avatar
doesnt have to be that big, thats just the one i have. it just has to be long enough to reach the hood latch and you still be able to reach it with a hammer
Old Dec 15, 2009 | 07:17 PM
Yeah ill see what I got and while I'm at it ima probleee put a new hood latch
Old Dec 15, 2009 | 07:20 PM
crx_si-r's Avatar
you wont need a new one. just spend some time adjusting it. also dont forget to adjust the little bump stops above the headlights. those adjust by twisting it like a screw
Old Dec 15, 2009 | 07:21 PM
Matt55's Avatar
just get 2 ppl like someone already said
jdmdingdong
Dec 26, 2010 10:38 AM
omega02379
Mar 21, 2009 05:39 AM
Nocturnal
46
Oct 2, 2005 05:14 AM
turboeg_4
Aug 29, 2005 05:51 PM
blueaccord94
Mar 26, 2005 07:53 PM
