Oil & Air Pressure Releasing From Valve Cover ... Bad Oil Leakage
Old Dec 15, 2009 | 11:47 AM
crxb16sir's Avatar
Default Oil & Air Pressure Releasing From Valve Cover ... Bad Oil Leakage
Before I put the cap on the valve cover i had a tube from valve cover to intake .... wen i had the mad oil was going into the manifold .... so i put the cap thinkin it would stop the oil spittin .... so with the cap on .... oil is shootin out the valve cover gromments .... im having lots of air pressure dont know wut to do ....
Old Dec 15, 2009 | 12:13 PM
DJYoshaBYD's Avatar
Default Re: Oil & Air Pressure Releasing From Valve Cover ... Bad Oil Leakage
looks like you have a leaky seal somewhere.. are you smoking out of the exhaust? are your spark plugs wet with oil? how does it run?
Old Dec 15, 2009 | 12:42 PM
Matt55's Avatar
i like how theres no question just a picture lol
Old Dec 15, 2009 | 12:53 PM
DJYoshaBYD's Avatar
hahaha
Old Dec 15, 2009 | 01:05 PM
airfed_teg's Avatar
I'm thinking your engine breathes somwhat through that breather port on the valve cover that u have blocked off , high engine pressures will cause most seals to blow
Old Dec 15, 2009 | 01:08 PM
Matt55's Avatar
lol, i didnt even notice that, put a little oil breather their compadre
Old Dec 15, 2009 | 01:09 PM
DJYoshaBYD's Avatar
Yeah, but a block/clogged PCV valve shouldnt do THAT much
Old Dec 15, 2009 | 02:30 PM
88efZ6's Avatar
That isn't the pcv he has blocked off its the line that is supposed to run to the intake tube. It needs to be vented last time I checked
Old Dec 15, 2009 | 03:12 PM
crxb16sir's Avatar
no smoke coming out from exhuast .... plugs arent wet .... runs good .... jus wen i run it spits out oil .... im guess cuz of the cap on the valve cover
Old Dec 15, 2009 | 03:13 PM
beansandrice's Avatar
Remove valve cover and replace gasket.
Grab screw driver and remove the vac line plug from your breather nipple.
That little thing should not be capped.
http://i57.photobucket.com/albums/g2...x/DSCN4916.jpg
Old Dec 15, 2009 | 03:14 PM
crxb16sir's Avatar
before i put the plug i had a hose from the valve cover to intake and all it did was send oil into manifold ..... so at that point it smoked ...
Old Dec 15, 2009 | 03:32 PM
iheartteal's Avatar
then get one of those little breather filter things or just let it vent out. pollution is great
Old Dec 15, 2009 | 03:39 PM
crxb16sir's Avatar
i had a breather filter and it filled up wit oil
Old Dec 15, 2009 | 03:45 PM
Your rings are going bad if you have that much blow by.
Old Dec 15, 2009 | 03:50 PM
airfed_teg's Avatar
I'm not 100% on the d series but on a b series, the stock setup, the intake manifold puts a vacuum on the crankcase (lot more to it), that air flows from the valve cover and in a stock setup that is the only place it draws air from, Honda engines also have some high crankcase pressure at high rpm's so it goes both ways, you have effectivly cut off the only supply of air to your internal engine, so it has made it's own way through your seals. Honda put it there for a reason, put it back or it will get worse , I'm
sure many others will vouch for me, especialy the turbo guys
Old Dec 15, 2009 | 04:15 PM
DJYoshaBYD's Avatar
well, if its filling up with oil, then you have bad seals seal that **** up.. a gasket kit with o-rings is only, like, 15 bucks
Old Dec 15, 2009 | 04:17 PM
DJYoshaBYD's Avatar
PCV = Positive Crankcase Ventilation
the ONLY reason its hooked up to the intake, is because the intake is already filtered air, so why would honda add another filter, when a cheap hose can be used instead to draw in filtered air..
but yeah.. a catch can would be nice.. lol..
Old Dec 16, 2009 | 12:27 AM
Davidss's Avatar
I would agree that if it's that bad you probably have pretty serious blow by.
vtec.dc2
Sep 10, 2003 10:08 PM
Kevin
Apr 22, 2002 09:02 PM
dieselboy
Aug 10, 2001 07:55 AM
