Wiring question
Old Dec 14, 2009 | 05:46 PM
b15's Avatar
b15
Default Wiring question
Wiring question: I've been reading diagrams all night and now im tired and just wanted some input
if you do an add-a-circuit on the dome light fuse, will whatever accessory you want to power be on all the time (since power is constantly running to this fuse in the box), or will it only be on when your dome light is on?
Old Dec 14, 2009 | 10:16 PM
Scott_Tucker's Avatar
Default Re: Wiring question
It should be on all the time. The door switch grounds the circuit.
Old Dec 15, 2009 | 05:31 AM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^.
The dome light circuit is "hot at all times".
What is it you want to add?
MM&Y of car? 94
Droop408
Lighting
Feb 15, 2019 06:00 AM
Jreycrx
May 4, 2010 02:32 PM
jimmy o.
Dec 9, 2008 09:21 AM
92DAturbo
Jan 4, 2008 06:13 PM
GoLowDrew
Lighting
Dec 20, 2007 06:29 AM
