obd II distributor for obd I set up?
Old Sep 2, 2002 | 09:14 PM
Gonzo's Avatar
Default obd II distributor for obd I set up?
Ok I just got my b20 vtec inside my engine bay, just waiting to start but I only have a distributor for a 98 gsr. My car is a 93 civic and the wiring is still for obd I. My question is, can I run that distributor for my engine? How could I make it work if possible? They both have a 2 pin and 8 pin connector. The 2 pin connector have the same wire color match, but the 8 pin connector have different wire colors for the wire harness and the distributor harness. Any help. Thanks
Old Sep 3, 2002 | 05:24 AM
No-Gi's Avatar
Default Re: obd II distributor for obd I set up? (Gonzo)
change the plugs from the OBD-II to the OBD-I distributor. i do it all the time. The only difference is that OBD-I has 2 plugs and OBD-II has 1. The wires are the same colors and its very simple
Old May 10, 2003 | 11:16 AM
yaya's Avatar
Default Re: obd II distributor for obd I set up? (3 South)
Old May 13, 2003 | 04:22 PM
dgcivic's Avatar
Default Re: obd II distributor for obd I set up? (yayaRl337)
SO...I can use my ba16a2 OBD 2 dist. on my obd1 wire harness?
someone help me out... wenrich@tds.net
Dave
Steve@PPD
Apr 20, 2007 01:49 PM
Ruby Civic
Mar 9, 2004 09:35 AM
Gonzo
Sep 3, 2002 05:04 PM
Gonzo
Sep 3, 2002 06:31 AM
Phat Corolla
Jun 18, 2002 12:28 PM
