Transmission & Drivetrain Gearboxes, Differentials, Clutches
4.4 and 4.78 fd
Old Dec 14, 2009 | 12:23 PM
that_sick_eg's Avatar
Default 4.4 and 4.78 fd
alrite i did some research and i couldnt find much info bout this. i jus get info about type r motors that have them 98spec and up and 96-97 have the 4.4.... i hear 2 stories out there that the 1 to 3 gears are basically the same but the 4th and 5th or diff.... then i hear other story sayin that they are really diff like nite and day...and some pople say theres no diff at all...well i have a jdm gsr with a 96-97 type r tranny 4.4 fd and lsd with basic bolts ons and intake mani..i wanna keep this all motor.... no boost in the future...prolly jus some interanl work.... i wanna switch the fd to 4.78 for better 1/4 mile times and acelleration... u think its worth it or should i jus keep the 4.4fd... i dont drive on the freeways as much so it wont matter bout that... if so id get the 5th gear of a gsr for 97.21 from acura dealership to put on it if i hated the rpms on the freeway.... well i was thinkin bout gettin the type r fd from hmo for 410 shipped....well if anyone got any input on this or has done a jdm gsr w 4.78 fd please let me kno pros and cons would be sweet
Old Dec 14, 2009 | 01:49 PM
80 dolla crx hf's Avatar
Default Re: 4.4 and 4.78 fd
You can use the 4.7 and since your in there swap to the ls 5th for gas mileage or switch to the gsr 5th instead of the itr 5th. Will give you a better cruising gear for the highway with the ls but if you did the gsr 5th you gain some beter mpg on the highway without 5th being to short.
But its your call.
Old Dec 14, 2009 | 04:36 PM
Aquafina's Avatar
Lower RPM does not mean better economy.
JDM 98+ ITR uses a 4.785 FD with GSR 4/5 gears. Pre 98 JDM ITR uses the same ratios as the B18C5/B16A2.
Depends on your plans for the engine, if you are going to keep it bolt on or even cam'd 1.8 then a 4.785 or 4.928 FD will work well depending on your tire size and RPM. If you are going to build it or go 1.9-2.0, then I would go with a close gear set.
Old Dec 14, 2009 | 07:07 PM
my plans is N/A and jus cammed.. nothin to big or serious... my tire size is 205/50/15
are you sure the 4.785 has gsr 4th and 5th gears???
Old Dec 14, 2009 | 07:12 PM
Aquafina's Avatar
What is your fuel cut set at?
Yes, I'm sure.
Old Dec 14, 2009 | 07:36 PM
Yes, I'm sure.
8400.... are u sure cuz in my buddy gsr at 80mph he sittin at 4k on the freeway.. and my buddy got a 98spec 4.7 fd on his b16 and at 80mph he at 5k?
Old Dec 14, 2009 | 09:00 PM
Aquafina's Avatar
Different tire sizes or speedometer is off. B16 5th and 4.7 is not 5k at 80 on common 23's.
Old Dec 14, 2009 | 09:04 PM
hmmmm i seen on some threads that with this tranny on diff motors they still sit at 5k in 5th at 80? the fd should change that so i kinda belive it
Old Dec 14, 2009 | 09:09 PM
Aquafina's Avatar
Engine doesn't matter. Gear ratio, final drive ratio, and tire size dictate the RPM for any given speed.
Old Dec 14, 2009 | 09:12 PM
so should i jus leave mine how it is then and not get the 4.7 fd?
Old Dec 14, 2009 | 09:27 PM
i compared the 96-97 typer r 4.4 fd to the 98spec 4.78 fd and i put the tires the same and everythin annd the mph is diff..... so was i rite... i should sit at 5k at 80 with the 4.78 fd.. cuz rite now wit the 4.4 fd i sit at 4k at 80
http://www.fatboyraceworks.com/gears...raph&Compare=1
Old Dec 14, 2009 | 09:49 PM
Aquafina's Avatar
B16 5th, 4.785 FD, and 23's = 4,700 RPM at 80mph.
Old Dec 15, 2009 | 01:00 AM
close to 5k lol
Old Dec 15, 2009 | 01:38 PM
Matt55's Avatar
Do you mean its not the ONLY thing in better fuel economy?
Old Dec 15, 2009 | 01:44 PM
Matt55's Avatar
troof
Old Dec 15, 2009 | 07:06 PM
Aquafina's Avatar
No. Higher RPM should net you better economy if you keep your foot out of it.
Old Dec 15, 2009 | 07:10 PM
Matt55's Avatar
explain, bc at higher rpm's your engine is obviously working harder thus burning more fuel
Old Dec 15, 2009 | 07:56 PM
im confused too lol
Old Dec 15, 2009 | 08:01 PM
Matt55's Avatar
for real, but i love to learn though
Old Dec 16, 2009 | 12:21 AM
VeilSide_Mas's Avatar
Well i think what he's trying to say is higher rpm up till a certain point where you're just barely touching the throttle to keep the car cruising (obviously you can't be barely touching the throttle to keep the car crusing at 6000rpm)
At that point you're not burning much fuel but you're going much faster, thus more mileage for the same amount of fuel.
Don't know if i make sense but i do get better mileage driving at 3500rpm on the freeways compared to 3000rpm haha so i was figuring out too
Old Dec 16, 2009 | 12:40 AM
95skunkedgsr's Avatar
think about load on the motor also
Old Dec 16, 2009 | 03:27 AM
Aquafina's Avatar
Correct. Lower gearing means less throttle needed to keep the car moving. Less throttle means less fuel, means higher economy.
Old Dec 16, 2009 | 05:32 AM
Matt55's Avatar
i agree, but i beleive in lower gear your ecu still makes more gas available, just like if you use cruise control you use less gas, because your ecu isnt expecting the chances of you flooring it, so i think it still oversprays in lower gear
Old Dec 17, 2009 | 06:58 PM
Hybrid96EK's Avatar
The ECU calculated fuel based off load. Its dictated by the MAP sensor (load). Less load at higher rpm to cruise then there is at lower rpm to cruise. Plain and simple.
Fastwhip
Apr 6, 2006 05:12 PM
High RPM
Mar 8, 2006 09:11 AM
pushinlsteg
Sep 21, 2005 03:36 PM
SupraDai
May 9, 2004 10:53 PM
LuckyNuts
Oct 16, 2003 03:01 AM
