Break problems galore
Old Dec 13, 2009 | 06:28 PM
bodiez's Avatar
Hit the floor!
Default Break problems galore
Ok so:
90 CRX DX with a b16 (meaning big teg brakes and hubs in front)
Disk front, drum rear brakes
First off, i wasnt braking right and i felt like the car was nose diving, so i adjusted the drums and immediately was better. A month or so goes by and the car starts to shake left/right when braking. Im thinking, the front brakes were doing 100% of the braking before i adjusted the drums so mayube the rotors warped. Pads looked good so i swapped out rotors and it braked good again.
Then, time goes by and it again feels like the drums are doing nothing. Put new drum pads on it and it feels better but now the front is shaking side to side when braking AGAIN.
Plus the pedal is getting soft. So what am i doing wrong? Should I just get new rotors/pads since I have new drums and ill be fine? I dont know why I am having so many problems braking. I downshift 90% of the time, dont drive like a moron.
WTF HT?
Old Dec 13, 2009 | 06:56 PM
91civisedaner's Avatar
Default Re: Break problems galore
Have you changed the fluid?? also did you swap the correct proportioning valve?? if you have a disc/disc valve it won't work correctly with disc/drums...also how are your wheel bearings???
btw what master cylinder are you use'in???
Old Dec 13, 2009 | 08:04 PM
bodiez's Avatar
Hit the floor!
Did not change fluid but levels are fine.
Did not have to swap a proportioning valve. Car was always disc/drums but the disc brakes in the front are now bigger. thats all
wheel bearings have been fine the last time i checked them. definitely a braking shaking.
Stock master cylinder. Thats getting changed next.
Old Dec 13, 2009 | 11:56 PM
You should change your master and flush/bleed your brakes.
Old Dec 14, 2009 | 12:26 AM
ef yu's Avatar
should have bought new pads with the new rotor.....sure the pads look fine to the naked eye, but I'm sure if the rotors were warped before, the pads went along with the grooves the rotors made.
Old Dec 14, 2009 | 12:29 AM
^^^Good point I forgot that one
Old Dec 14, 2009 | 01:17 AM
Clipsed's Avatar
yup!
Did you bleed the brakes properly after you put on the new brakes up front?
Old Dec 14, 2009 | 02:40 AM
DCRB's Avatar
don't forget, drums warp too!
Old Dec 14, 2009 | 03:49 AM
Clipsed's Avatar
when you say shaking do you mean the steering wheel?
Old Dec 14, 2009 | 06:27 PM
jaje's Avatar
I'd be more concerned about a bad front bushing, ball joint, spring perch, strut could be blown. Also check your steering rack to make sure it's torqued down correctly, and tie rods are good. It's very, very hard to diagnose a problem like that just by description.
Old Dec 28, 2009 | 11:26 AM
bodiez's Avatar
Hit the floor!
ok so update:
put a new master cylinder in today and bled all 4 brakes throughly. Front two were bled until new fluid was coming up. Brakes feel better but there is still a bad side to side vibration when braking at a speed around 30 to 50 mph.
What next?
Calipers?
I replaced the rotors recently, could they be warped again already?
Old Dec 28, 2009 | 12:36 PM
4drEF's Avatar
Keyboard Humorist
Did you clean the rotors and pads off with brake cleaner before using them?
They come shipped with a coating that needs to be removed - if not you can get hot spts and uneven braking.
How did you drive for the first couple hundred miles on your brand new rotors?
Without bedding the brakes in properly you can warp the rotor with hot spots.
Hard to tell if it's even brake related - can't tell how much vibration you are talking about.
Old Dec 28, 2009 | 04:30 PM
bodiez's Avatar
Hit the floor!
no i did not. big mistake.
I do not know how to bed in brakes when first installed. apparently I am really doing stuff the wrong way.
How do you do that?
Old Dec 28, 2009 | 04:42 PM
4drEF's Avatar
Keyboard Humorist
http://lmgtfy.com/?q=bedding+brakes
Old Dec 28, 2009 | 08:45 PM
bodiez's Avatar
Hit the floor!
hahah **** you.
thanks
Misfit2613
Suspension & Brakes
13
May 29, 2015 05:20 PM
Hatchd
Apr 3, 2006 10:40 AM
Lewie
Apr 13, 2005 05:44 PM
ExAcc
Oct 28, 2002 05:57 AM
1hotintegra
10
Aug 7, 2002 07:01 PM
