welding shortshifter
Old Dec 13, 2009 | 05:26 PM
projectTeG's Avatar
Default welding shortshifter
alright i got a question for you guys. i got a ss b and m shifter its origionally a straight on but i was to make it bent. i have already cut it and shaped it to the shape i want, now i cant weld it will my flux mig. i have access to a gas mig welder can that weld the ss?
Old Dec 13, 2009 | 05:29 PM
redboost10's Avatar
Default Re: welding shortshifter
yes you can mig weld it but you need tri mix gas and ss wire.
Old Dec 14, 2009 | 12:32 AM
jjspec's Avatar
Tig it.
Old Dec 14, 2009 | 01:32 AM
Vagitarian's Avatar
Fluxcore doesnt weld stainless???
Old Dec 14, 2009 | 05:35 AM
Karl Buchka's Avatar
Sure it does.
Old Dec 14, 2009 | 11:14 AM
projectTeG's Avatar
not good, the weld is brittle
Old Dec 14, 2009 | 01:05 PM
onefstek's Avatar
just tig it, make sure that you take out the bushings out of the shifter so they don't melt.
Old Dec 14, 2009 | 01:24 PM
It's not going on the space shuttle. Just weld it with whatever you have.
Old Dec 14, 2009 | 01:32 PM
onefstek's Avatar
You want to make sure you weld it good so you don't end up with the end of the shifter in your hand when it brakes from the weld.
Old Dec 14, 2009 | 02:38 PM
projectTeG's Avatar
i have punched my radio by breaking a shifter, im up to 2 time shifting and the **** in my hand at the end of the shift. i welded it with the flux mig and hit the shifter with a hammer to test the weld and snapped within the first 2 hits.
Old Dec 14, 2009 | 03:06 PM
essex's Avatar
What machine is it?
Maybe you need go slower and turn up the heat.
Really has nothing to do with fluxcore being the problem.
Is it tubing or solid?
Old Dec 14, 2009 | 03:11 PM
projectTeG's Avatar
solid ill try that
Old Dec 14, 2009 | 03:51 PM
essex's Avatar
if its solid try to bevel the edges with a grinder or belt sander or something....try sticking it in the oven for a while too
Old Dec 14, 2009 | 05:13 PM
projectTeG's Avatar
****! i forgot about that thats whay we had to do to weld cast potmetal, preheated the metal with a rose bud.
ej1995
Nov 24, 2013 12:14 PM
Dkahn18
Welding / Fabrication
13
Dec 28, 2008 09:38 PM
Spooled1.6L
Feb 17, 2004 10:11 AM
Pineapple Devil
Oct 1, 2002 12:20 PM
sir6
Sep 14, 2002 10:38 AM
