** how often do you guys change your spark plugs?
Old Sep 2, 2002 | 08:23 PM
ELUD THS's Avatar
New User
Default ** how often do you guys change your spark plugs?
how often do you guys change your spark plugs. i use NGK copper ZFR7F-11, anm ive heard about 10,000 miles then change. is that true? i have a 5th gen lude.
Old Sep 2, 2002 | 09:18 PM
Def's Avatar
Def
Default Re: ** how often do you guys change your spark plugs? (ELUD THS)
Errr... brain fart - I'm not boosted, so I'd say change yours at least as often as you're changing them, if not sooner.
They're cheap as hell, and it definitely lets you keep on top of how your motor is running. No point in stretching something out that's so freakin' cheap and vital to your motor's function.
[Modified by Def, 10:25 PM 9/2/2002]
Old Sep 2, 2002 | 09:46 PM
ELUD THS's Avatar
New User
Default Re: ** how often do you guys change your spark plugs? (Def)
true. but still like to know other peoples opinion. thanks though
Old Sep 2, 2002 | 10:12 PM
Rocket's Avatar
Just change them when you feel they have lost power. Otherwise you should be cool. I've done alot of R&D on spark plugs and found them to work best after a month of running them so brand new is not nessarily better.
Old Sep 4, 2002 | 09:11 AM
ELUD THS's Avatar
New User
Default Re: ** how often do you guys change your spark plugs? (Rocket)
ttt
Old Sep 4, 2002 | 10:01 AM
SIK IN DA HED's Avatar
New User
can you prove that?
i change mine every month.
Old Sep 4, 2002 | 10:11 AM
DIRep972's Avatar
Smarter than you
I change mine every other oil change and sometimes sooner.
Old Sep 4, 2002 | 10:39 AM
CovertFI's Avatar
Default Re: ** how often do you guys change your spark plugs? (DIRep972)
hmmmmm maybe i should change mine? cant remember the last time
Old Sep 4, 2002 | 12:35 PM
Rocket's Avatar
Default Re: ** how often do you guys change your spark plugs? (dlplayboy)
can you prove that?
Thats been my experience. I might have some dyno proof in the near future.
Old Sep 4, 2002 | 05:23 PM
ELUD THS's Avatar
New User
thanks maybe its time to change mine again/
Old Sep 4, 2002 | 06:47 PM
Hellz99si's Avatar
I agree I have ZEX Turbo/Nitrous plugs and they have been in about a month now....must say that they feel a bit stronger now.
Old Sep 4, 2002 | 08:36 PM
Madness's Avatar
Default Re: ** how often do you guys change your spark plugs? (Hellz99si)
i've heard some scary chit about those zex plugs dropping electrodes
and killing motors -- justa word of caution
Old Sep 4, 2002 | 08:58 PM
turboex's Avatar
Default Re: ** how often do you guys change your spark plugs? (dante_420)
Ok heres a quick question, i know everyone one uses, the mgk bk7res11 or some thing like that, but i need some plugs supa fast for the dyno tomorrow, and i dont have time to get some ordered. is there anything else i can get? that is colder than stock for a 8to1 compression b16 running 14-20psi of boost? via hondata of course. thanks guys
Old Sep 4, 2002 | 09:01 PM
FBP Si 2000's Avatar
Ditto...
Old Sep 4, 2002 | 10:15 PM
Rocket's Avatar
Thanks dude. More often than not it seems like the engine looses a little pep when I change the plugs.
Old Sep 4, 2002 | 10:26 PM
Arturbo's Avatar
Better than steak
25 Year Member
there has already been a dyno with new plugs and you do indeed loose some power. I wonder why that is?
Old Sep 4, 2002 | 10:37 PM
Rocket's Avatar
Default Re: ** how often do you guys change your spark plugs? (Arturbo)
There has to be a little crud that promotes flame kernal growth. New plugs don't have the crud.
Old Sep 4, 2002 | 11:36 PM
ion_four's Avatar
That's interesting, because I've seen dyno's that say otherwise (comparing old vs. new and "fancy"; POS 4 electrode Bosch among others)...maybe we should hold them in a flame before putting in new plugs
Old Sep 5, 2002 | 02:22 AM
New User
however, there is also the unrecognized fact that the crud can also prevent the spark plug from supplying a strong spark.
Old Sep 5, 2002 | 04:27 PM
blackteg's Avatar
Default Re: ** how often do you guys change your spark plugs? (turboex)
Olympic Import Parts carries them in stock in. I never have to order them, in and out in 5 minutes.
Old Sep 5, 2002 | 07:04 PM
integra-modder's Avatar
me too, about every 10K
Old Sep 5, 2002 | 10:00 PM
ELUD THS's Avatar
New User
Default Re: ** how often do you guys change your spark plugs? (integra-modder)
thanks for all the info.
Old Sep 5, 2002 | 10:01 PM
ELUD THS's Avatar
New User
also how can you tell your spark plugs are about to go. i heard they misfire.
so if there about to go will you feel a lag in boost?
Nshouse0003
Jun 20, 2011 09:03 AM
veritasaequatis
14
Feb 6, 2007 03:08 PM
JDlvl InTEGRA
Feb 6, 2003 04:48 PM
2k1 GSR
Jan 12, 2003 02:33 AM
TeamTooQuick
Jun 19, 2002 10:12 PM
