cluster swapping trouble shoointg
Old Dec 13, 2009 | 02:49 PM
wongburger's Avatar
Default cluster swapping trouble shoointg
i have a 91 civic std that is a 4 speed and i just bought a new cluster that came out of a 88 crx si i have no tach but swapping because of tach but wonder what i would have 2 do 2 make all this work besides rewiring because i do not have the light clip that comes on the back because it did not come with one but do have the old one from my gauge cluster so is here anyway to hook that up and hook this cluster up like plug a play or do i have 2 rewire everything?
Old Dec 13, 2009 | 03:03 PM
miguey310's Avatar
Default Re: cluster swapping trouble shoointg
x2
Old Dec 13, 2009 | 03:06 PM
wongburger's Avatar
same problem?
Old Dec 13, 2009 | 03:18 PM
civiccrx's Avatar
You should hve done your research before buying that cluster. Cluster plug and play:
88<->89 and 90<->91
Otherwise you'll need to pinout the harness yourself; there are pinouts available by searching this site.
Old Dec 13, 2009 | 03:28 PM
wongburger's Avatar
figured that out afterwards was just gunna compare the clips and see which wires do where will that work i do have the original clip from the crx attached the gauges
Old Dec 13, 2009 | 05:00 PM
civiccrx's Avatar
I seriously think it's going to be worth your while to just sell the 88-89 cluster and get a 90 or 91 Si cluster.
The time it will take you to do this work, you would have made enough money at work to buy the right one.
Someone who knows what they're doing and can figure out wiring diagrams can swap this out no problem. It sounds to me that you are in for more than your money.
Old Dec 13, 2009 | 05:07 PM
wongburger's Avatar
i can read diagrams and follow the mapping i would just have 2 relocate the pins in the clip i hope but i about 2 just go switch it for the normal one
Old Dec 13, 2009 | 06:10 PM
spikehead221's Avatar
From: Staring down the barrell of my 12 ga. Texas, USA
dont waste your time trying to repin. i was gonna swap in a crv cluster in mine, but realized the pain it would be, so i bought the si of my year. plug and play is beautiful
Old Dec 13, 2009 | 07:18 PM
KINGVEM^^ED6's Avatar
Bump for a sale and rebuy.....if not go buy sum advilllll
Old Dec 13, 2009 | 08:39 PM
Clipsed's Avatar
haha! x2!
Euphorex
Oct 31, 2013 02:53 AM
91EF919
Sep 17, 2007 01:51 PM
Project_EF
12
Feb 11, 2005 07:19 AM
B16CRXT
10
Oct 26, 2004 04:16 PM
88hondahatch
10
Oct 25, 2002 06:39 AM
