Difference between T3 .48 and .63
Old Dec 13, 2009 | 02:42 PM
rx7_'s Avatar
Default Difference between T3 .48 and .63
Hey guys, would like to know what are the differences between a T3 .48 hotside and .63 hotside? Any difference in power output? Im currently using a china turbo, its a T3 but no a/r stated on the turbo, guy i bought from doesn't know the a/r of it too. also, what are the start spools of both in a d16? Thanks.
Old Dec 13, 2009 | 02:54 PM
TheShodan's Avatar
Moderator
Default Re: Difference between T3 .48 and .63
this depends a lot upon what exhaust wheel is used, but generally, max torque output for a given level of boost pressure is shifted higher in the power band the larger the volute size is. "spool" doesn't change a lot, the differences are a bit subtle compared to the other factors such as exhaust wheel size.
Old Dec 13, 2009 | 10:42 PM
Joseph Davis's Avatar
If it's an OEM-equivalent piece of china garbage, you aren't going to see a big difference. 200 rpms quicker spool and you'd need a dyno to measure the power difference as the butt dyno can't pick up 10-15 whp on that scale.
Garretts express their turbines in a wierd fashion, the actual "nozzle" size varies as a function of the A/R ratio and the turbine wheel size. Basically, as either AR or turbine gets larger so does the nozzle. With smaller turbines the nozzle size doesn't change much as the AR changes, but it has an amplified effect when combined with larger turbines.
Can't really say where your turbo will spool at. Or, I could but don't care to type that much to properly relate it all. Can you give me an idea which turbine you have? If you are at a loss, measure the turbine wheel's exit and we will ASSume that the turbo behaves like a Garrett.
Old Dec 14, 2009 | 07:11 AM
TheShodan's Avatar
Moderator
If you're not sure how to measure, here you go.
Wheel measurement
A/R Measurement
Trim measurement
greygoose
Dec 21, 2008 08:27 AM
crj_lll
May 24, 2005 09:59 PM
Don Johnson
Sep 22, 2004 04:55 PM
JDMx05
Jun 5, 2004 11:17 AM
boosted hybrid
Jan 15, 2003 03:28 PM
