how to route the intercooler piping
I have a 99 civic turbo iv had it for a couple years but i just bought some coilovers to replace my oem suspension. My question is how have you people routed you intercooler piping on the driver side with the washer fluid resevoir, mine passes just below it but when my car will be lowered it might hit on bumps or steep inclines. I thought about relocating it and even molding it but i just wanna see what others on here thought, btw i have lots of time i put the car in storage till next spring
how close is your compressor to the washer fluid bottle? you should be able ot get away with a u bend right into the intercooler without to much of an issue..what turbo manifold and turbo are you using?
I forgot who makes it but they have a direct replacement washer fluid reservoir that is smaller in depth which allows you to move the intercooler piping alittle higher then it would be if you kept the stock reservoir.
92, 98, civic, intercooler, intercooling, pipe, piping, put, resivor, route, routing, turbo, washerfluid
