Apexi neo/safc/vafc wires to wire colors on ecu write up
since the apexi diagrams are crap and dont really show you anything
i kind of made all honda friendly. let me know if you have any questions
UNIT wire: ECU wire:
White wire: Airflow and pressure signal red/green
Pink wire: VTEC signal output green/yellow
Light green wire: VTM signal Blue/Black
Purple wire: VTEC signal input green/yellow
Red wire: IG Power yellow/black
Green wire: rpm blue/silver
Red and white wire: IG Power yellow/black
Gray wire: Throttle signal (TPS) Red/black
Brown wire: Ground
Black wire: Ground
i believe this is the write wiring, if someone can double check this id appreciate it
Yellow wire: Airflow and pressure signal (map sensor) red/green
Brown wire: Ground
Black wire: Ground
I can't verify the wire colors, but when installing these units I don't even look at the wire colors, I just look at the pinouts. Sometimes people change the wires or maybe you'll get an international car that will use different colored wires to the ECU.
i have a 94 honda civic with a jdm d15b vtec i cannot find out how to wire my apexi s-afc to my p08 ecu please god help me i tryed your thing and i didnt work should also let you know i have the orignal cx wire harness for the car i have been looking for 3 days so please if you can help i will not blow up the world lol ive never known fustration like this befor!!
wuhungsixxx
Jul 18, 2002 03:39 AM
