Secondary air injection with test pipe
Its not really necessary to have secondary injection if i have a test pipe right?could i just "U" tube the 2 lines on the motor side?
uhmm... AP1's definetely have a secondary air injection pump..... for the OP though i dont know the answer, i do know however there is a delete kit available from different companies for the air injection pump
do you have a link?i just tubed the ends of the lines on the intake manifold side temporarily.
yes,would i need to chip it or something?if its a big expense then i might just hook up the 2nd air injection.
i didnt do it,i bought it like that with the lines open.i just tubed the lines on the motor side incase the air goes into the motor.
ill just get the pump and hook it all back up.
btw the the pump is completely useless after the cold start right?if it still pumps some air after the cold start then i could just keep the lines plugged so the air goes in the engine and makes a bit more power
It has no benefit other than emissions
