Need help want to do away with key and make just push start
Old Dec 12, 2009 | 03:46 PM
925EKCOUPE's Avatar
Default Need help want to do away with key and make just push start
I have a track car i am building and want to know what wires i need to make a push start for my car right now i just have the cirlce plastic white piece that you crank with a screw driver so here is what i am asking
1. what wires do i use for the fuel pump on one switch
2.what wires do i use for the start of the car starter wire and solinoid
3.what wores do i use for the accesory stuff on one switch
its a 96 honda civic thank you for looking and helping
Old Dec 14, 2009 | 07:21 AM
90Rexx's Avatar
Default Re: Need help want to do away with key and make just push start
once your done let me know where the car is parked ;-) haha lol do u seriously want to remove the best piece of security a car has just for convenience?
good luck though should be an interesting outcome if you can get it to work!
Old Dec 14, 2009 | 08:25 AM
97Ej6mike's Avatar
For push start, at least on the S2000's, you have a key that turns to 2nd accessory, but the actual starter is controlled by way of the Pushbuttom start. So a simple pushbutton would still require a key. As for eliminating a key all togather, im not sure how one goes about doing that. Your best bet would be a haynes/chiltons service manual that has a layout of wiring diagrams of the specific things you are looking to hardwire.
Old Dec 14, 2009 | 08:57 AM
newtron63h's Avatar
ok, need to know a few things first.
antitheft or no? keyless entry or no?
once i get that, im gonna post the diagrams on my photobucket then ill do a writeup on what wires to do what with.
KrushaTV
Mar 25, 2018 01:33 AM
tampabitches
Aug 14, 2006 02:56 PM
94eg2sol
15
Feb 1, 2006 04:51 PM
hondapwred95
Sep 2, 2005 03:15 AM
crvtechjin
63
Jul 12, 2005 03:11 PM
