Drove car through puddle now CEL on
Old Dec 12, 2009 | 02:59 PM
heyitsaej8's Avatar
Default Drove car through puddle now CEL on
So I just drove my car throw a big puddle (not a puddle that goes up to my bumper) but when I drove through it water jumped up to my engine bay.
I don't have a fender liner on my passenger side (the side the car went in the water), I'm lowered 2.5 inches and have a Short ram intake. My car started to try to stall and the CEL started to blink and stayed solid. before it stayed solid I pulled over and shut my car off.
I drove home and it run normal, but tries to stall sometimes.
I unplug the battery and clean the spark plugs. I plan on draining the oil soon.
What do you guys suggest me do?
SORRY NO CEL CODE FOR NOW.
Any help would help.
Thanks
Cliffs:
-Drove through puddle
-CEL blinked and stayed on
-engine tried to stall and sometimes tries to stall when driving.
-unplug battery and dried spark plugs
Old Dec 12, 2009 | 04:11 PM
Linked's Avatar
Default Re: Drove car through puddle now CEL on
did you have a splash guard on at the moment?
Old Dec 12, 2009 | 04:34 PM
supersize's Avatar
let your intake dry
c if you got water in your dist cap
let plugs dry
unplug battery for 5 mintus and replug it back on
start the car and c if it throws the code again
Old Dec 12, 2009 | 06:20 PM
heyitsaej8's Avatar
The car runs better now, i change the oil/filter, spark plugs and turned off the CEL. thanks for the help.
Old Dec 16, 2009 | 08:03 PM
heyitsaej8's Avatar
well the car started and it stalled. and then it wouldnt turn on so i kept starting the car, after couple of minutes it started.
today after driving a couple of miles the engine check light came up and blinked fast. now its solid. do u guys know what it might be?
its a 1998 civic ex
Im going to pull the code tommrow.
maybe a egr?
Old Dec 16, 2009 | 08:09 PM
CRXREFIC's Avatar
its very easy to pull the code, anyways was your intake wet?
Old Dec 16, 2009 | 08:50 PM
Former User's Avatar
The EX has no EGR system. When you pulled the plugs, was there water in the cylinders? Have you removed the distributor cap to check for water inside?
Old Dec 17, 2009 | 02:10 AM
heyitsaej8's Avatar
oh okay. yeah i didnt see a egr valve, there was no water in the plugs or caps. Imma go to autozone tommrow to check for my code. any ideas what it can be?
my intake was somewhat wet but not wet enough for water to be dripping out of the filter
Old Dec 17, 2009 | 02:27 AM
TheRappist's Avatar
Is water 'pooling' anywhere at all in your intake system? This means from the filter all the way to the end of the runners in the intake manifold. Find out
Old Dec 17, 2009 | 04:57 AM
98civtec's Avatar
yai would take off the short ram and the throttle boddy and just take a look to see if there is any condensation left over from any water being in side there
Old Dec 19, 2009 | 10:04 PM
heyitsaej8's Avatar
well out of no where i guess the CEL turned off out of no where when i started the car. any ideas if i should check out the engine even though the CEl isnt coming back on? or should i just leave it alone. my car actualyl sounds liek i have a intake on still even though I took off my SRI.
drb53
Honda Fit
Jun 2, 2017 03:30 PM
361 accord
Jun 15, 2010 02:47 PM
Bird333
May 3, 2010 05:24 PM
prelude2perfect
Mar 13, 2008 06:44 AM
