rear disk brake conversion questions please help...
Old Dec 12, 2009 | 08:22 AM
mynameizstitch's Avatar
Default rear disk brake conversion questions please help...
ok i got a 1993 honda civic cx and want to do a 1996 integra rear disk brake conversion. my question is i already got almost the complete the whole rear conversion but missing the parts where i circle in red. will i be needing those too or do will my stock rear drum setup already have those arms? also will i be needing integra e-brake cable and integra rear brake lines also since the rear conversion i got did not come with them?
Old Dec 12, 2009 | 08:46 AM
yellowjdmcrx's Avatar
Default Re: rear disk brake conversion questions please help...
yes ur drum set up will have that. and yes u will need teg or civic with rear disk ebrake calbes and brake lines. its a easy swap.
Old Dec 12, 2009 | 08:53 AM
Lasky's Avatar
yes you do already have those pieces on your drum set-up and they are usable however you cant just buy any teg or civic with rear disc brake lines.. you'll need the SI hatch ebrake lines considering your car is a hatch the coupe and sedan civic ebrake lines wont work and the integra ones might but i would just go with the SI with rear disc e brake cables
GL bro
Old Dec 12, 2009 | 11:28 AM
GL bro
are you sure i would need just the si ones? cuz its gonna be a hella of a lot harder to find that compare to ex or integra ebrake lines. can anyone confirm this???
Old Dec 12, 2009 | 01:28 PM
PacoEJ's Avatar
GL bro
i got an Ekhatch n got integra disc brakes n "LINES" from the integra. They work fine in my car well better then the drums i had.
Old Dec 12, 2009 | 02:11 PM
Doc13's Avatar
You could get aftermarket ones: Skunk2,Buddy Club,Etc..That way you can adjust your rear camber settings too.
Just a thought.
Old Dec 12, 2009 | 03:23 PM
24TEN's Avatar
PHANTOM MENACE
...however you cant just buy any teg or civic with rear disc brake lines.. you'll need the SI hatch ebrake lines considering your car is a hatch the coupe and sedan civic ebrake lines wont work and the integra ones might but i would just go with the SI with rear disc e brake cables
GL bro
Exactly why won't the coupe/sedan ebrake lines work? And why "might" the integra one work?
Old Dec 12, 2009 | 03:39 PM
the integra one will work man and so would a coupe i am pretty ****ing sure, mine has integra lines on it
Old Dec 12, 2009 | 04:41 PM
supersize's Avatar
i wanna do that to mine haha
Old Dec 13, 2009 | 07:51 AM
so integra rear brake lines will also be needed correct?
Old Dec 13, 2009 | 03:06 PM
PacoEJ's Avatar
either both the same integra or SI
crunchy_taco
Apr 25, 2007 11:01 PM
ACURATSX
Mid-Atlantic (Sales)
Nov 18, 2005 03:26 PM
wongf22b2
Apr 26, 2004 02:55 PM
untitled
Sep 5, 2003 02:35 PM
