Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
tl-s calipers on accord?
Old Dec 11, 2009 | 09:47 PM
PilotOnDubs's Avatar
Default tl-s calipers on accord?
anyone have 04 and up acura tl type s brembo 4 piston calipers on their 03 and up accord?
i heard its possible, but havent seen it in person. if so, what was done to make them fit and on which accord? 4 cyl/v6... i did a search and only found info for civics and integras
Old Dec 13, 2009 | 09:35 PM
Default Re: tl-s calipers on accord?
anyone?
Old Dec 15, 2009 | 01:38 PM
slowcm5accord's Avatar
huh. thatd be nice. i have an 07 4cyl.
thatd be a simple, but nice and affective upgrade. let me know if you find anything else out further.
good luck on your research
Old Jan 5, 2010 | 08:58 PM
k24aCCord sI-R's Avatar
that is a very possible mod. i tried it but ended needing more parts and ultimately i changed my mind. all you need is to buy are the...calipers, tl-s brake lines, tl-s knuckles then everything after that is the obvious like pads and flushing the brake lines. If you have a v6 all you have to do is modify the thread pattern and make it smaller so the stock bolt can be utilized and its a straight bolt on no tl-s knuckles required.
trmn8r69
May 23, 2017 10:23 AM
and9300
May 4, 2012 03:35 AM
sinister2c
May 8, 2006 07:03 AM
revhrdls
Sep 27, 2001 08:07 AM
