STARTER SHAKES!!!
Old Dec 11, 2009 | 08:54 PM
:::SIRll_EJ1:::'s Avatar
Icon2 STARTER SHAKES!!!
SO, my semi rebuilt B16a2 powerd EJ1 isnt starting due to lack of SPARK, ive changed all the fuses including main relay,got new dizzy,alternator,plugs/wires etc...
when attempting to start the car my friend noticed that my starter was shaking. the reason for the shaking is that one of the Bolts that hold the starter to the tranny isn't there... why? the threads are efffed up and i'm too lazy to tap new threads.
my question to you is that would my starter not being fully mounted cause the engine to lose spark or not start??
Old Dec 11, 2009 | 08:59 PM
fcm's Avatar
fcm
Old Fart
Default Re: STARTER SHAKES!!!
No, but you will have to get off your *** and heli-coil that damage thread and install a mounting bolt before you have bigger problems. 94
Old Dec 11, 2009 | 09:01 PM
haha thanks man i will, what bigger problems might run into???
Old Dec 12, 2009 | 06:45 AM
fcm's Avatar
fcm
Old Fart
At the very least a damaged starter or flywheel, if the starter engages when misaligned it could break completely free of its mounting, [one bolt] taking a chunk of the tranny housing with it. 94
Old Dec 27, 2009 | 10:39 PM
enjoi_hendrix's Avatar
i believe that could be a reason for it not starting. there are two wires that go to your starter. the smaller gauge wire coming from your harness that goes to your ignition, and the ground that runs to your battery. if the starter isnt fully up against your tranny then youre not getting a good ground connection. goin thru the same **** right now so i hope this helps lol
Mhollaek9
Honda CR-V & Element
Apr 27, 2024 06:46 PM
LoicJoncourt
Aug 8, 2013 03:30 AM
:::SIRll_EJ1:::
Dec 12, 2009 06:29 AM
crx1856
Aug 20, 2003 10:24 PM
Elite Hatch
Nov 24, 2002 10:06 PM
