96 civic wont start
ok, today my car wouldn't start after i let it sit all day, i checked the main relay, fuses in engine compartment and inside of car, next i checked to see if i get spark to the distributor and no spark, which wire do i test on the plug that goes to the distributor to check if its getting power?
Check the Blk/Yel wire attached to the coil inside the distributor. You should neasure battery voltage with the key in ON(II).
Does the fuel pump prime for 2 seconds when the key is turned to ON(II)?
Any CEL codes?
Any CEL codes?
Does the car even have power? Its possible its a weak or dieing battery, this happened to my car yesterday.
