no heat?
Old Dec 11, 2009 | 05:54 PM
thegatekeeper14's Avatar
Default no heat?
alright i just changed my thermostat, and befor that i had carbord infron of my radiator. while i drive hwy the temp gauge reads normal but when i come to a stop or drive city wide, my coolant drops?
Old Dec 11, 2009 | 07:44 PM
Default Re: no heat?
yeah i just drove my car and it still drops in temp on the gauge and the vents.
Old Dec 11, 2009 | 08:11 PM
fcm's Avatar
fcm
Old Fart
Sounds like thermostat is stuck open, at highway speeds the engine is working "harder" so coolant heats up, airflow and the rad fan will keep temp. at "normal", at city speeds there is less steady load on the engine, if thermostat does not close, engine coolant will cool down. 94
Old Dec 11, 2009 | 08:35 PM
should i get a another new one and hope that one was defulty
Old Dec 11, 2009 | 08:53 PM
fcm's Avatar
fcm
Old Fart
Check your rad hoses, if both are the same temp. all the time, thermostat is not closing, pull it and replace it, make sure it is installed properly. 94
Old Dec 12, 2009 | 06:02 AM
lol well it only fits in one way. ill check today, its cold here in mn
Old Dec 12, 2009 | 06:34 AM
fcm's Avatar
fcm
Old Fart
Spring towards engine, jiggle pin at the top. 94
Old Dec 12, 2009 | 07:33 AM
well upper rad is warm luke warm, and lower is cold.
i have radiator cap off and blower motoe turnned way up.
i just replaced the head gasket on monday. and im almost 100% sure its not that.
Old Dec 12, 2009 | 08:06 AM
both hoses to the fire wall are warm also.
i had my car ideling in this MN cold for about 45 min and it never touched the C on the gauge. although there was luke warm air cominf from the vents. nothing more nothing hot!
Old Dec 12, 2009 | 05:00 PM
nos487's Avatar
maybe get a hotter thermostat.
Old Dec 12, 2009 | 09:08 PM
i dunno if thats it, see my headgasket went bad and it over heated, bad coolant leak, i noticed it in the exhaust, and had a hard time starting the car in the mornings, now thats all fixed. but heat is now an issue, just sucks cuz i feel like a teenage girl, i had to much, now i cant get enough, lol.
Old Dec 13, 2009 | 06:43 AM
xzodiackillerx's Avatar
take the stat out and see if it is open at all. you can put it in a pot of hot water on the stove and watch it open.. then make sure you bleed all of the air out of the system.
Old Dec 13, 2009 | 09:00 AM
fcm's Avatar
fcm
Old Fart
The problem here is not is the thermostat is opening, but is it closing, the symptoms, [low engine temp. and low heat] indicate a thermostat not closing, or, as mentioned, not closing at the correct temperature, too low. 94
Old Dec 13, 2009 | 09:25 AM
well ill replace it again
CUTTERSPOOL
Oct 21, 2012 11:05 AM
MikesEJ1
May 13, 2012 03:13 PM
mherrcat
Mar 20, 2011 03:04 PM
litterbox
Mar 16, 2009 06:50 AM
lax1089
Feb 3, 2007 02:17 PM
